What Actually Determines Quick Turn PCB Turnaround Time
211 0 Aug 11.2026, 16:48:09
KEY DEFINITION  A quick-turn PCB is a circuit board fabricated and often assembled on an accelerated schedule, anywhere from 24 hours to about a week instead of the usual two to three weeks. The actual turnaround depends on layer count, via structure, surface finish, and how complete the design files are at submission.
You pay for the 24-hour option assuming the clock starts the second you hit submit. Two days later, a message shows up asking for a drill file, and the fast turnaround you paid for has already slipped.
A quoted 24-hour turnaround isn't always the turnaround you get. Here's what actually controls the timeline of a quick turn PCB order, and how to keep yours on track.
What Actually Determines a Quick Turn PCB's Timeline
Turnaround on a quick turn PCB order comes down to five variables, not one fixed number printed on a website.
  • Layer count and stack-up: A simple two-layer board moves through fabrication in a fraction of the steps a 12-layer board needs, so layer count usually sets the baseline timeline before anything else is factored in.
  • Via structure and lamination cycles: Blind, buried, or stacked microvias require sequential lamination, and each additional lamination cycle repeats drilling, plating, and pressing steps, which adds real days to the schedule rather than hours.
  • Surface finish: A finish like OSP applies quickly, while heavier gold finishes involve a longer plating process, so the finish chosen on the fab drawing can shift the delivery date by a day or more.
  • File completeness: Missing drill charts, unclear stack-up notes, or an incomplete BOM send the order back for clarification before fabrication can even start, which erases any time advantage the quick turn service offered.
  • Assembly complexity: Fine-pitch components, BGAs, or mixed through-hole and SMT builds add programming and inspection time on top of bare-board fabrication.
Because these variables stack on top of each other, the fastest way to estimate a realistic delivery date is to compare board types side by side.
Standard PCB Lead Time vs. Quick Turn PCB Lead Time
Standard PCB manufacturing typically runs 10 to 20 business days depending on complexity, while quick turn service compresses that same work into a much narrower window. The table below shows typical ranges across the industry, though exact timing always depends on a specific shop's queue, capacity, and the design's actual complexity.
Board TypeStandard Lead TimeQuick Turn Lead Time
1 to 2 layer5 to 7 business days24 to 48 hours
4 to 8 layer7 to 10 business days2 to 4 business days
10 to 16 layer10 to 15 business days4 to 7 business days
HDI or rigid-flex15 to 20+ business days7 to 12 business days
These ranges assume the files arrive complete and correct the first time, which is where most quick turn orders actually lose their speed advantage.
What to Prepare Before Requesting a Quick Turn Quote
A quick turn order moves fast only when the manufacturer can start fabrication immediately, which means the file package needs to be complete before it's submitted.
  • Gerber or ODB++ files with a matching drill chart: These need to reflect the final design revision, not a draft that still needs edits.
  • A complete bill of materials with manufacturer part numbers: Missing MPNs or vague substitutions force a pause for sourcing confirmation before assembly can begin.
  • A fabrication drawing with stack-up and impedance callouts: This tells the fab house exactly which layers, materials, and tolerances apply, preventing rework later in the process.
  • Clear surface finish and class requirements: Stating whether the board needs IPC Class 2 or Class 3, and which finish, avoids a mid-order clarification request.
  • Test requirements defined up front: Flying probe versus in-circuit testing needs, and any special test points, should be spelled out before the order starts, not after.
Even with a complete package, a handful of recurring mistakes still slow quick turn orders down more often than fabrication capacity ever does.
Common Mistakes That Turn "Quick" Into "Not So Quick"
Most quick turn delays trace back to file issues rather than actual production bottlenecks.
  • Footprint mismatches between the BOM and the layout: A part listed in the BOM that doesn't match the footprint on the board triggers a manual review before assembly can proceed.
  • Unclear via-in-pad callouts: Vias placed in surface mount pads need explicit plating and fill instructions, or the order stalls while the fab house asks for clarification.
  • Inconsistent layer naming or missing plated versus non-plated drill separation: This forces engineers to guess at intent instead of fabricating on schedule.
  • Skipping a design review to save a day: Catching a spacing or annular ring violation after fabrication starts costs far more time than a same-day check would have.
A manufacturer that runs a real design review on every order, rather than treating quick turn as a shortcut past quality checks, is usually the difference between a fast board and a fast do-over.
How PCBgogo Keeps Quick Turn Orders Both Fast and Accurate
Since file errors are what actually derail a quick turn schedule, the manufacturing partner's process for catching them before production starts matters as much as its stated turnaround time.
  • Per-order DFM and engineer review: Every order goes through a manufacturability check before fabrication begins, catching the footprint mismatches and stack-up issues that otherwise cause delays mid-run.
  • 24-hour expedited delivery: For designs that qualify, PCBgogo offers 24-hour turnaround, matching the fastest end of the quick turn range covered above.
  • In-house fabrication through assembly: PCBgogo runs fabrication and assembly under one roof, so a board doesn't wait on handoffs between separate fab and assembly vendors.
  • AOI and X-ray inspection on every order: Speed doesn't replace inspection here; automated optical and X-ray checks run as a standard part of the process, not an optional add-on.
  • Native file support for Eagle, Altium, and PADS: Uploading directly from common design tools skips a conversion step that otherwise adds friction to getting an order started.
For specifics on a given layer count, via structure, or finish, PCBgogo's online quoting tool gives an instant read on what's realistically achievable for that design.
What is considered a quick turn PCB?
A quick turn PCB is a board fabricated and often assembled on an accelerated schedule, typically ranging from 24 hours to about a week. The exact cutoff varies by manufacturer, but it always means compressing standard fabrication steps into a shorter window.
How fast can a quick turn PCB actually be delivered?
Simple one or two-layer boards can ship in 24 to 48 hours. More complex builds, like 10-layer or HDI boards, usually take 4 to 12 business days depending on via structure and lamination cycles.
Does a quick turn PCB cost more than a standard order?
Yes, expedited fabrication typically carries a premium since it takes priority in the production queue. The exact cost depends on layer count, quantity, and complexity, so checking an online quoting tool gives the most accurate number.
Can multilayer or HDI boards still qualify for quick turn service?
Yes, though the timeline extends compared to a simple board because each additional lamination cycle adds fabrication steps. A 12-layer or HDI board can still move faster than standard lead time, just not as fast as a two-layer design.
What causes a quick turn PCB order to get delayed?
The most common causes are incomplete file packages, missing bill of materials details, and unclear stack-up or finish callouts. A manufacturer that runs a DFM check before fabrication starts catches most of these issues early.
Do quick turn PCBs go through the same quality checks as standard orders?
They should. A reliable manufacturer applies the same AOI, X-ray, and inspection standards to quick turn orders as it does to standard production runs, since speed shouldn't come at the cost of reliability.
Quick turn PCB timelines are shaped less by a manufacturer's marketing claim and more by layer count, via structure, and how complete the files are on day one. Getting the file package right the first time is usually what separates a board that ships in 24 hours from one that sits in review.
For a specific design, running it through PCBgogo's quoting tool is the fastest way to see what turnaround is actually realistic.
