Altium PCB Design Tutorial From Schematic to Fabrication
14 0 Nov 19.2026, 19:04:00
QUICK ANSWER  For a reliable Altium PCB design, build and validate the schematic, confirm every footprint, set the board shape and layer stack, then transfer the design to the PCB. Place parts around their physical connections, set fabrication rules before routing, run a full design rule check, and inspect Gerber and drill files before ordering.
A board that looks finished in Altium can still fail at assembly: a header may face the wrong way, or a drill file may not line up with the copper. This Altium PCB design tutorial follows an example 45 × 35 mm, 3.3 V temperature-sensor board with a microcontroller, I2C sensor, regulator, LED, and four-pin connector. Use the sequence for your own circuit, checking dimensions and manufacturing limits against the parts and board you actually intend to buy.
Altium PCB Design Workflow
1. Create the Project and Schematic
Choose File > New > Project, then add a schematic document. Place parts from the Components panel and wire the power, ground, and signal nets. Name the I2C lines and annotate designators. Before moving on, compare each symbol pin number, footprint pad number, package size, and connector orientation with its datasheet. A correct circuit with a mirrored connector footprint is still a failed board.
2. Validate the Electrical Design
Right-click the project and select Validate PCB Project. Read the Messages panel and fix unintended unconnected pins, naming mistakes, and power conflicts. On the example board, check that the sensor has its supply decoupling capacitor and that its I2C pull-ups connect to the intended 3.3 V rail. Only mark a pin as intentionally unconnected after checking the datasheet.
3. Set the Board Shape and Copper Layers
Add a PCB document to the project. In Board Planning mode, use Design > Redefine Board Shape for the outline, and locate mounting holes from the enclosure drawing. Open Design > Layer Stack Manager to set copper layers, board thickness, and materials, then save the stack to the PCB. For this low-speed sensor board, two layers may be enough if routing leaves a sound ground return. Choose four layers when density or return-path needs justify them; confirm the proposed stackup with the fabricator before setting impedance constraints.
Layer Choice            Practical Decision
2 layersSimple, low-speed board; keep ground return as continuous as placement and routing allow.
4 layersDense routing or a need for dedicated reference and power planes; confirm the stackup first.
4. Transfer Components and Place Them for Assembly
In the schematic editor, choose Design > Update PCB Document, then Validate Changes and Execute Changes in the Engineering Change Order. Check that every component arrives with the expected footprint. Place the connector and mounting holes first; next position the regulator, microcontroller, and sensor. Keep each decoupling capacitor close to its supply pins, leave room for the mating cable, and use 3D view to inspect orientation and enclosure clearance.
5. Set Rules and Route
Open Design > Constraint Manager if the project uses it; otherwise use Design > Rules. Set trace width, clearance, via, copper-to-edge, and solder-mask rules from the intended fabrication capability, not from a generic default. Use Route > Interactive Routing to connect power and signals, then add and repour a ground polygon. On the two-layer example, avoid cutting the ground return with long traces beneath the sensor and microcontroller. Altium PCB design rules only protect what you configure and enable.
6. Run the Checks a Board View Cannot Show
Choose Tools > Design Rule Check and review every reported issue, especially unrouted nets, clearance, width, solder-mask slivers, and copper near the edge. Inspect silkscreen over pads, drill sizes, connector pin 1, and component height separately. If a violation is deliberate, document the reason; do not simply disable its rule to make the report look clean.
7. Export and Inspect the Manufacturing Package
Create an Output Job with Gerber and NC Drill outputs, or use File > Fabrication Outputs from the PCB editor. Include the used copper, solder mask, silkscreen, and the mechanical layer carrying the outline. Keep Gerber and drill units, format, and origin consistent, then open the exported files in a CAM viewer to check layer alignment and holes. For assembly, also prepare a BOM, pick-and-place file, and assembly drawing. When uploading to PCBgogo, match the quote options to your actual layer count, thickness, copper weight, finish, and any special requirements. This final review turns Altium PCB design files into a usable manufacturing handoff.
Good Altium PCB design depends on a chain of small checks. Verify the part models before layout, use the real manufacturing limits while routing, and inspect the exact files you will submit. That sequence catches costly mistakes while they are still easy to fix.
Can I Submit an Altium File to PCBgogo?
PCBgogo accepts Altium design files. For a clearer fabrication handoff, also review the Gerber and drill outputs yourself and state any special stackup or machining needs in the order.
Why Are Parts Missing After Update PCB Document?
Check that the schematic component has a valid PCB footprint, save and validate the project, then run the update again. Read the Engineering Change Order messages before executing changes.
What Is Needed for PCB Assembly Besides Gerbers?
Supply a BOM with exact part numbers, a pick-and-place file with side and rotation, and an assembly drawing. Confirm that designators agree across all three files.
