Hard Anodizing for CNC Parts Benefits and Design Guide
85 0 Sep 09.2026, 10:26:47
Hard anodizing is one of the most effective ways to improve the wear resistance, corrosion protection, and electrical insulation of CNC machined aluminum parts. Also called hard coat anodizing or Type III anodizing, the process converts the aluminum surface into a dense aluminum oxide layer. It is especially useful for sliding components, housings, valve bodies, fixtures, and other parts that must remain lightweight while surviving repeated contact or harsh service.
The finish cannot be treated as a cosmetic step added after machining. Hard anodizing changes dimensions, follows the existing surface texture, and may alter color depending on the alloy. A successful part therefore starts with the correct coating specification, machining allowance, masking plan, and inspection criteria.
What Is Hard Anodizing
Hard anodizing is an electrochemical conversion process used mainly on aluminum and its alloys. The part becomes the anode in a chilled acid electrolyte while direct current drives controlled oxide growth. Unlike paint or plating, the oxide is formed from the aluminum itself and remains integral with the substrate.
Type III processing generally uses lower bath temperatures and higher current density than conventional Type II sulfuric anodizing. These conditions create a thicker, denser layer with smaller pores and greater abrasion resistance. A common production range is about 25 to 75 micrometers, although the appropriate thickness depends on the alloy, geometry, tolerance, and performance requirement. If a drawing cites MIL PRF 8625 Type III without a thickness, the buyer and supplier should still confirm the intended build because default practices and contract requirements can differ.
Hard alumimun CNC
Hard Anodizing vs Regular Anodizing
Both processes improve aluminum surfaces, but they solve different problems. Type II anodizing is usually selected for moderate corrosion protection, decorative color, and low dimensional impact. Type III hard anodizing is selected when wear life and surface durability matter more than bright, repeatable color.
PropertyType II anodizingType III hard anodizing
Primary purposeProtection and appearanceWear and engineering performance
Typical thicknessAbout 5 to 25 micrometersAbout 25 to 75 micrometers
Typical hardnessOften about 200 to 300 HVCommonly 400 HV or higher depending on alloy
Color rangeBroad and easier to controlUsually gray bronze brown or black
Dimensional effectUsually modestMust be included in tolerance planning
Common CNC useCovers panels housings and consumer partsBushings rails pistons valve parts and wear surfaces
Harder is not automatically better. A decorative enclosure with close color requirements may be better served by Type II. A bearing surface exposed to sliding abrasion may justify Type III. Selecting the finish from the service condition prevents unnecessary cost and avoids dimensions that become difficult to hold.
How the Hard Anodizing Process Works
A typical production route includes cleaning, optional etching or surface preparation, deoxidizing, racking, anodizing, rinsing, optional dyeing, and sealing when required. The rack must carry electrical current, so it leaves a small contact mark. The drawing should identify where a rack mark is acceptable when appearance or function makes location important.
The anodizer controls bath chemistry, temperature, current density, and processing time to reach the specified thickness. Geometry affects current distribution. Outside faces usually build more consistently than deep bores, blind pockets, and narrow internal passages. Auxiliary cathodes may help on difficult cavities, but they require planning with the finishing supplier before production.
Sealing closes pores and normally improves corrosion resistance and stain resistance. It may also reduce abrasion performance or interfere with a later dry film lubricant. For sliding parts, the requirement may be unsealed hard coat, a specialized seal, or a lubricant-filled finish. The correct choice depends on whether corrosion, wear, friction, or chemical exposure controls the design.
Key Benefits for CNC Machined Parts
Wear resistance is the main reason engineers specify hard anodizing. The ceramic-like oxide protects aluminum surfaces that would otherwise scratch, gall, or wear rapidly. This allows a designer to keep the low mass and machinability of aluminum while improving the working surface.
  • Abrasion resistance for guides, pistons, pulleys, rollers, and repeated-contact surfaces
  • Corrosion protection for equipment exposed to humidity, salt, oils, and many neutral chemicals
  • Electrical insulation because aluminum oxide is nonconductive
  • Better resistance to handling damage than decorative anodizing
  • A porous surface that can accept selected sealants or solid-film lubricants
The coating is hard but thin, and the aluminum beneath it still carries the structural load. Hard anodizing does not increase the core strength of a weak section, repair poor machining, or make every aluminum alloy perform the same way.
Material Selection and Appearance
6061 aluminum is a common choice for hard anodized CNC parts because it machines well and generally produces a consistent coating. 6082 and selected 5xxx alloys can also perform well. High-strength 7075 is widely used, but its alloying elements can reduce coating hardness or create a darker, less uniform appearance. High-copper 2xxx alloys and cast aluminum with substantial silicon may show greater color variation and lower wear performance.
Natural hard coat color is controlled partly by alloy chemistry and coating thickness. It can range from light gray to bronze, brown, or nearly black. A dyed black finish is possible, but exact shade matching across different alloys, heat lots, surface preparations, or production batches should not be assumed. When appearance is critical, use one alloy and temper, define the pre-anodize finish, and approve a physical sample or limit sample.
CNC Hard Anodizing
Dimensional Growth and CNC Tolerances
Type III oxide grows partly into the original surface and partly outward. A practical planning rule is that roughly half of the specified coating thickness appears as outward growth, although the actual ratio varies with alloy and process conditions. At a 50 micrometer coating thickness, an exposed surface may move outward by about 25 micrometers. A coated shaft may therefore gain about 50 micrometers in diameter, while a coated bore may lose about 50 micrometers.
Nominal hard coatApproximate growth per surfaceApproximate diameter change
25 micrometers12.5 micrometers25 micrometers
50 micrometers25 micrometers50 micrometers
75 micrometers37.5 micrometers75 micrometers
These figures are useful for early design, not a substitute for a supplier-specific allowance. Coating thickness has a tolerance, and deep or shielded features may receive less oxide than open surfaces. For press fits, bearing seats, precision bores, sealing lands, and mating threads, define whether the final dimension applies before or after anodizing. When the tolerance is narrower than the expected coating variation, masking or post-finish machining is usually safer than relying on compensation alone.
Design Rules That Prevent Common Failures
Plan Threads and Fits Before Machining
Hard anodizing can tighten internal threads and enlarge external threads. Thick oxide may also interfere with gauges and mating parts. Critical threads are commonly masked, while noncritical threads may be machined with an agreed allowance. Do not leave the decision to a general note such as finish all over.
Use Radii on Coated Edges
Sharp corners concentrate current and make coating thickness less uniform. The oxide is also more likely to chip at knife edges. Add a real radius where possible, especially as coating thickness increases. A small broken edge or chamfer does not distribute the coating as evenly as a radius.
Specify the Surface Before Anodizing
Anodizing follows the machined texture and often increases measured roughness. It will not hide cutter marks, scratches, dents, or blended rework. If the final part must be matte, brushed, bead blasted, or polished, state the preparation method and cosmetic surfaces. Blasting can soften edge definition and change dimensions, so it should be included in the process plan rather than requested after machining.
Identify Masked and Conductive Areas
The anodic layer is electrically insulating. Grounding pads, electrical contact points, bonding surfaces, and some sealing faces may need masking. Mark them clearly on the drawing and define whether a secondary conversion coating is required for corrosion protection on exposed aluminum.
How to Specify Hard Anodizing on a Drawing
A useful drawing note removes choices that could change function. At minimum, define the applicable specification, Type III, class or color, coating thickness and tolerance, sealing condition, surfaces to mask, rack-mark location, pre-anodize preparation, and dimensions that apply after finishing.
A practical callout could read: HARD ANODIZE PER MIL PRF 8625 TYPE III CLASS 1 50 MICROMETERS PLUS OR MINUS 10 MICROMETERS UNSEALED MASK IDENTIFIED THREADS AND BEARING BORES DIMENSIONS MARKED AFTER FINISH APPLY AFTER BEAD BLASTING.
The exact note should match the project standard and the anodizer's qualified process. If coating thickness must be verified on a functional face, show the measurement location. Otherwise, an accessible witness area may be measured while a deep bore receives a different thickness.
Inspection and Quality Checks
Inspection should follow the risks identified on the drawing. Thickness can be checked with an eddy-current instrument on suitable accessible surfaces. Finished dimensions should be measured after anodizing when fit is critical. Visual inspection should distinguish acceptable rack marks and alloy-related shade variation from burns, pits, powdery areas, scratches, or incomplete coverage.
For demanding production parts, the purchase requirement may also include coating weight, microhardness, abrasion testing, corrosion testing, electrical breakdown, or a certificate of conformance. Avoid requesting every test by default. Select the checks that verify the actual failure mode, and agree on sampling before the first batch.
When Hard Anodizing Is Not the Best Choice
Choose another finish when the part needs bright, tightly controlled decorative color; when tolerances cannot accommodate coating variation; when electrical continuity is required across most surfaces; or when fatigue performance at highly stressed features is the dominant concern. Type II anodizing, chemical conversion coating, electroless nickel, a dry film lubricant, or a different base material may fit the requirement better. The correct comparison is based on load, motion, environment, tolerance, and expected life.
Hard Anodizing Questions for CNC Projects
How thick is hard anodizing
Many CNC parts use 25 to 75 micrometers of Type III coating. Around 50 micrometers is a common engineering target, but the drawing should state the required value and tolerance rather than rely on an assumed default.
Does hard anodizing change dimensions
Yes. Roughly half of the coating thickness may grow outward from each coated surface. This increases external dimensions and reduces internal dimensions. Complex cavities may not coat uniformly, so confirm critical allowances with the anodizer.
Can 7075 aluminum be hard anodized
Yes. 7075 is frequently hard anodized, but it may produce lower coating hardness and a darker or less uniform natural color than 6061. Functional requirements should take priority over cosmetic expectations.
Should hard anodizing be sealed
Seal when corrosion and stain resistance are the main priorities. Unsealed or specially treated hard coat may be preferred for maximum abrasion performance, dry film lubricant adhesion, or controlled friction. State the sealing condition on the drawing.
Can hard anodizing cover machining marks
No. It reproduces the existing surface and can make defects more visible. Define the required machined roughness, blasting, brushing, or polishing before the anodizing operation.
Final Design Checklist
Before releasing a CNC machined part for hard anodizing, confirm the aluminum alloy and temper, the Type III thickness, sealing and color, dimensional allowances, masked features, rack location, edge radii, prefinish texture, and final inspection method. Review these items with the machining and finishing suppliers before the first article. That short review is usually less expensive than reworking a batch of parts whose bores, threads, color, or surface texture changed after coating.
