CNC Titanium Machining: A Complete Guide to Alloys and Process
119 0 Aug 20.2026, 15:38:49
KEY DEFINITION  CNC titanium machining shapes titanium alloys, most often Grade 5 (Ti-6Al-4V), into precision parts with carbide tooling, controlled cutting speeds, and high-pressure coolant. Titanium's low thermal conductivity and tendency to work harden make it harder to cut than aluminum or steel, so tool choice, machine rigidity, and thermal control determine part quality and cost.
Titanium looks like a simple material choice on a spec sheet: light, strong, corrosion resistant. On the shop floor it behaves more like a stubborn negotiation, refusing to give up heat, hardening exactly where you just cut, and grabbing onto tool edges it should slide past.
This guide covers the titanium grades used in CNC machining, why the material resists cutting, and the tooling, process, and finishing decisions that turn a difficult metal into a reliable part.
The Titanium Grades Used in CNC Machining
Titanium for CNC machining splits into two families: commercially pure grades (1 through 4) and alpha-beta alloys reinforced with elements like aluminum and vanadium. Commercially pure titanium machines more easily and resists corrosion well, but it carries less strength, so it tends to end up in chemical processing equipment and marine hardware. Ti-6Al-4V, known as Grade 5, makes up roughly half of global titanium consumption and is the default choice for aerospace brackets, fasteners, and structural parts because of its strength-to-weight ratio. Grade 23, the extra-low-interstitial version of Grade 5, trades a little strength for better ductility, which is why it shows up in orthopedic implants and surgical instruments.
GradeTypeRelative MachinabilityTypical Use
Grade 2Commercially pureGoodMarine hardware, chemical processing, medical instruments
Grade 5 (Ti-6Al-4V)Alpha-beta alloyFairAerospace structures, automotive, tooling
Grade 23 (Ti-6Al-4V ELI)Alpha-beta alloy, low interstitialFairMedical implants, surgical hardware
Grade selection sets the ceiling on how easily a part will cut. Even in its most machinable grades, though, titanium still wears tools faster than steel or aluminum, and that comes down to the metal's underlying properties.
Why Titanium Is Difficult to Machine
Titanium's machining difficulty comes from four properties working against the cutting tool at the same time: low thermal conductivity, work hardening, chemical reactivity, and strength that holds up even as the cut heats.
Low thermal conductivity: Titanium conducts heat at roughly one-sixth to one-seventh the rate of steel, so instead of flowing into the chip, heat concentrates at the cutting edge and shortens tool life.
Work hardening: Cutting pressure and heat harden the surface layer during a pass, so the next pass has to cut through tougher material than the one before it.
Chemical reactivity, or galling: At high cutting temperatures, titanium reacts with the tool surface and welds small amounts of material onto the edge, degrading surface finish and eventually chipping the tool.
Retained strength at temperature: Unlike aluminum, which softens as it heats up, titanium holds much of its strength through the cutting zone, keeping cutting forces high for the entire pass.
Together, these four factors explain why titanium tool life is often a fraction of what the same tool achieves in aluminum, and why the machining process has to be built around managing heat rather than just removing material fast.
The Titanium CNC Machining Process
Machining titanium successfully means slowing down in the right places, not everywhere. A typical process runs through milling, turning, and drilling or boring operations on a rigid multi-axis machine, using lower cutting speeds paired with steady feed rates and a constant flow of coolant.
Roughing removes most of the stock quickly while leaving a controlled margin, often a fraction of a millimeter, for the finishing pass. On stress-sensitive parts, a pause between roughing and finishing lets the material relax before final dimensions are cut, which helps prevent the part from moving out of tolerance later. Finishing passes run at lighter depths of cut and rely on sharp, well-supported tooling to hold surface finish without generating extra heat. Milling favors a general surface speed in the range of 60 to 100 feet per minute for titanium, adjusted for the specific alloy, tool coating, and coolant strategy in use.
Cutting Tool Selection for Titanium Alloys
Cutting tools for titanium need to resist heat as much as wear, which is why coated carbide dominates titanium work in most shops.
Coated carbide inserts: Coatings such as titanium aluminum nitride form a protective oxide layer at high temperature, insulating the carbide substrate and extending tool life well beyond an uncoated tool.
Sharp, positive-rake geometry: A positive rake angle reduces cutting force and heat generation, which directly slows work hardening on the freshly cut surface.
Trochoidal or high-efficiency toolpaths: Maintaining a consistent tool engagement angle instead of plunging straight into corners prevents shock loading and reduces the re-cutting of chips that drives up heat.
Tool choice and toolpath strategy work together. A premium-coated tool run with an aggressive, shock-loading toolpath will still fail early, while the right combination extends tool life and keeps cost per part in check.
Finishing, Deburring, and Surface Treatment for Titanium Parts
Titanium's toughness that makes it hard to cut also makes its burrs stubborn, so deburring and finishing usually need a dedicated step rather than a quick manual pass.
Vibratory tumbling works well for small parts, using abrasive media to knock down burrs evenly. For internal features that are hard to reach mechanically, electrochemical deburring dissolves burrs without touching the surrounding surface. Once burrs are cleared, surface treatment shapes both function and appearance: anodizing builds a durable oxide layer that improves corrosion resistance and can add color without paint, bead blasting produces a uniform matte finish that also improves fatigue life through compressive stress, and polishing delivers the smooth, reflective surface needed for parts where friction or aesthetics matter most.
Five-Axis CNC Machining for Complex Titanium Geometries
Five-axis CNC machining lets the cutting tool approach a titanium part from multiple angles in a single setup instead of requiring the part to be repositioned for each face.
Fewer setups: Machining most or all faces without re-fixturing removes a major source of cumulative dimensional error.
Better tool access: Contoured surfaces, deep pockets, and undercuts that are difficult or impossible on a 3-axis machine become reachable.
Higher accuracy on complex features: Keeping the tool tangent to a curved surface throughout the cut produces a more consistent finish and tighter geometric control.
For titanium parts with compound angles or organic contours, such as aerospace brackets or implant geometries, five-axis machining is often the difference between a part that meets spec on the first article and one that needs rework.
Titanium vs. Aluminum for CNC Machined Parts
Choosing between titanium and aluminum comes down to matching material properties to the part's actual loads and environment, not simply picking the stronger metal.
PropertyTitanium (Grade 5)Aluminum (6061)
Density4.43 g/cm32.70 g/cm3
Relative strengthVery highModerate
Corrosion resistanceExcellent, self-passivatingGood, but galvanic risk with dissimilar metals
MachinabilityDifficultExcellent
Relative costHighLow
Titanium wins where strength-to-weight ratio, high-temperature performance, or corrosion in harsh chemical or marine environments matter most, which is why it dominates aerospace structures and medical implants. Aluminum remains the better choice for high-volume parts, consumer electronics housings, and any application where titanium's strength is unused headroom rather than a real requirement.
How to Prevent Titanium Part Distortion During Machining
Titanium distortion mostly traces back to residual stress inside the material being released unevenly as machining removes material around it.
Staged roughing and finishing: Leaving a consistent margin during roughing and removing it in a separate finishing pass avoids cutting straight to final dimension in one operation, which tends to lock in uneven stress.
Stress relief between stages: A thermal or vibratory stress-relief step between roughing and finishing lets the part settle before critical dimensions are cut.
Low-clamping-force fixturing: Once a part is stress-relieved, fixtures need to hold it securely without introducing new clamping stress that shows up as distortion after the part is released.
Skipping any one of these steps tends to show up later, often after a part has already passed inspection and started to move on the shelf.
How to Evaluate a CNC Partner for Titanium Machining
The right question when vetting a titanium supplier is not just "can you cut it," but whether the shop's equipment, process discipline, and quality system are actually built around titanium's specific failure points.
Machine rigidity and setup capability: High cutting forces demand a rigid, well-supported machine; a shop that hesitates when asked about workholding for thin-walled titanium parts is a warning sign.
Material and process knowledge: A supplier should be able to speak specifically to how machining Grade 5 differs from Grade 2, not just recite that titanium is hard to machine.
Documented quality systems: Certifications such as AS9100 or ISO 13485 signal that a shop's process control extends beyond the machine tool to inspection and traceability.
Manufacturability feedback before production: A partner that reviews wall thickness, radii, and tool access before quoting catches distortion and tool-access problems while they are still cheap to fix.
That last point is where a lot of titanium projects go wrong, since problems caught after the first article cost far more to fix than the same issue flagged at the design stage. PCBgogo's CNC machining service builds manufacturability review into the quoting process, so a titanium part's tricky corners or deep pockets get flagged before the first cut rather than after inspection.
The Bottom Line
Titanium delivers a strength-to-weight ratio and corrosion resistance that few metals can match, but it demands specific tooling, cutting parameters, and process discipline to machine well. Getting the grade, tool selection, and stress management right the first time is what separates a titanium part that ships on schedule from one that ends up back on the machine for rework.
What is the best titanium grade for CNC machining?
Grade 2 machines most easily among common titanium grades, but Grade 5 (Ti-6Al-4V) is the default for most CNC parts because of its strength-to-weight ratio, even though it costs more tool life to cut.
Why does titanium wear out cutting tools so quickly?
Titanium's low thermal conductivity keeps heat concentrated at the cutting edge instead of flowing into the chip, and its tendency to work harden makes each subsequent pass cut through tougher material.
Is five-axis machining necessary for titanium parts?
It is not required for simple prismatic shapes, but for parts with compound angles, deep pockets, or contoured surfaces, five-axis machining reduces setups and cuts the risk of cumulative dimensional error.
How can I reduce the cost of a titanium CNC machined part?
Simplifying geometry, using generous internal radii, minimizing the number of setups, and reserving tight tolerances for only the features that truly need them all reduce machining time and tool wear.
What surface finish works best for titanium implants and aerospace parts?
Anodizing is common for both corrosion resistance and color coding; bead blasting suits parts that need a uniform matte look and improved fatigue life; and polishing fits applications where surface friction or appearance is critical.
