Wireless Charger Circuit PCB Design and Manufacturing Guide
7 0 Oct 16.2026, 19:51:36
KEY TAKEAWAYS  A wireless charger circuit transfers power through a controlled magnetic field, but its PCB must do more than connect components. It must maintain coil resonance, remove heat, manage electromagnetic noise, detect foreign metal, and preserve alignment. Reliable production therefore depends on electrical design, mechanical stack control, and measurable manufacturing criteria.
Key Takeaways
  • Treat the coil as part of the circuit: PCB coil geometry, ferrite, air gap, and nearby metal change inductance, Q factor, and heat.
  • Design for the target profile: A Qi2 PCB must preserve the approved transmitter design's magnetic alignment and electrical behavior.
  • Specify production controls: Give the factory the stack-up, finished copper, critical dimensions, coil drawing, and test limits.
  • Validate FOD in the enclosure: Foreign object detection depends on calibrated power loss and resonance, not only a bare-board test.
  • Separate automotive requirements: AEC-Q wireless charging uses qualified components, but AEC-Q does not certify the bare PCB or finished charger.
A charger can pass a functional bench test and still overheat in the final housing because a phone case, magnet ring, ferrite sheet, or metal bracket changes the magnetic system.
This guide shows how to turn a wireless charger circuit into a manufacturable PCB, with practical checks for Qi2, automotive use, thermal control, and FOD.
What Is a Wireless Charging PCB
A wireless charging PCB drives a transmitter coil, communicates with the receiver, regulates power, and protects the product. A typical board includes input protection, a switching bridge, resonant capacitors, a controller, current and voltage sensing, temperature inputs, and the coil connection.
The transmitter may use a wound litz-wire coil or an integrated PCB coil. A PCB coil simplifies assembly at low power, but finished copper, trace geometry, turns, and vias become performance-critical features.
How Does Wireless Charging Work
A wireless charger circuit converts DC into high-frequency alternating current and drives a resonant transmitter coil. The receiver rectifies that energy, while load modulation sends control data back so the transmitter can adjust power or stop.
Qi2 introduced the magnetically aligned Magnetic Power Profile; Qi v2.0 specifies 360 kHz operation for that profile. Initial Qi2 products supported up to 15 W, and version 2.2 added a 25 W tier. Designers must freeze coil position, magnet geometry, and the mechanical stack with the electronics.
Wireless Charging PCB and Wired Charging PCB Differences
The main difference is that wireless power transfer depends on a tuned magnetic system, whereas wired charging delivers current through a direct conductive path. That changes the PCB layout, control loop, thermal model, and production tests.
Design AreaWireless Charging PCBWired Charging PCBProduction Impact
Power pathResonant bridge and coilConnector and regulated DCCharacterize loss and resonance
Mechanical sensitivityAir gap, alignment, ferrite, magnetsConnector fit and cable resistanceTest the final enclosure
Safety controlCommunication, thermal limits, FODCurrent, voltage, thermal limitsMore calibration states
EMI focusSwitching loop and magnetic structureConverter switching loopsReview coil paths and shielding
Because the coil is part of both the electrical and mechanical design, wireless production needs tighter coordination between PCB, assembly, enclosure, and validation teams.
Wireless Charging PCB Manufacturing Challenges
The hardest manufacturing issues are repeatable AC resistance, stable resonance, low-loss current paths, controlled heating, and accurate alignment between the board, coil, ferrite, magnets, and enclosure.
  • Copper and current paths: Use short bridge-to-coil connections, adequate finished copper, balanced copper, and multiple vias at layer changes. Define PCB coil copper and geometry on the fabrication drawing.
  • Component placement: Keep gate-drive loops compact, place resonant capacitors near the bridge, and isolate current-sense and communication nodes from high dv/dt copper.
  • Thermal paths: Move MOSFET, capacitor, connector, and coil heat into planes, thermal vias, the housing, or a heat spreader. Test at poor alignment, where loss can increase.
  • Mechanical datum control: State the coil and magnet centers, ferrite outline, board datum, adhesive thickness, and air-gap limit. Drift can break Qi2 PCB interoperability.
  • Factory data package: Release fabrication and assembly data, stack-up, finished copper, coil specification, critical dimensions, and resistance and functional test limits.
Wireless Charging PCB Safety and Foreign Object Detection
Foreign object detection identifies conductive objects that can absorb magnetic energy and heat. Qi methods include resonance or Q-factor checks before full power and power-loss accounting during operation, comparing transmitted and receiver-reported power after calibrated losses.
FOD starts with a stable wireless charger circuit. Current sensing, coil resistance, capacitor tolerance, ferrite position, temperature, and enclosure metal affect the baseline; firmware cannot reliably mask uncontrolled hardware variation.
Test representative phones, cases, offsets, gaps, temperatures, and defined metal objects. For a wireless charger for car, repeat testing under vibration and the specified cabin temperature range, with safe shutdown for communication or sensing faults.
Choosing a Quality Wireless Charging PCB Manufacturer PCBgogo
A capable manufacturing partner should convert the risk items above into documented engineering checks and measurable inspection steps. PCBgogo can support this work through published controls that match the needs of resonant power boards and automotive projects.
  • Engineering review: PCBgogo can review stack-up, finished copper, spacing, thermal paths, panelization, and dimensional tolerances before the Qi2 PCB reaches validation.
  • Imaging and inspection: LDI and AOI support registration and defect detection; electrical testing checks opens and shorts. Specify four-wire testing for critical low-resistance paths.
  • Verification options: TDR, X-ray, and microsection analysis are available when required. The purchase specification should name the reports, coupons, cross-sections, and acceptance class.
  • Automotive production planning: For an AEC-Q wireless charging assembly or wireless charger for car, identify AEC-Q100 ICs and AEC-Q101 discrete parts, then state IATF 16949 controls, traceability, IPC class, and reliability tests separately.
This approach does not replace system certification, but it gives the wireless charger circuit a controlled manufacturing baseline for thermal, FOD, EMC, and interoperability validation.
Summary
A reliable wireless charger circuit is a coupled electrical, magnetic, thermal, and mechanical system. Freeze the coil and enclosure stack with the PCB, specify measurable manufacturing controls, and validate FOD across real operating conditions; those steps matter as much as selecting the controller or drawing the schematic.
Can a PCB Coil Replace a Wound Wire Coil
Yes, a PCB coil can work at suitable power levels, but its AC resistance and Q factor may be less favorable than litz wire. Compare both in the final ferrite and enclosure stack.
Does a Qi2 PCB Automatically Make a Product Qi2 Certified
No. A Qi2 PCB is one subsystem; the complete product must follow an approved design path and pass applicable interoperability, power, communication, magnetic, thermal, and safety tests.
What Files Should I Send for Wireless Charging PCB Production
Send fabrication and drill data, stack-up, finished copper, assembly drawings, BOM, centroid data, coil and ferrite specifications, critical dimensions, and the test plan. Mark mandatory requirements clearly.
Does AEC Q Apply to the PCB Itself
AEC-Q standards qualify component families, such as ICs under AEC-Q100 and discrete semiconductors under AEC-Q101; they do not certify a bare PCB. An AEC-Q wireless charging product still needs board-level manufacturing controls and system validation for the vehicle program.
What Changes When Designing a Wireless Charger for Car
A wireless charger for car must handle the vehicle power environment, EMC, temperature, vibration, mechanical retention, and repeatable phone placement. Define the OEM test plan early because consumer bench testing does not cover those conditions.
