RA Copper vs. ED Copper: How to Choose for Flexible PCBs
KEY TAKEAWAYS RA copper is usually safer for circuits that bend repeatedly because its elongated grains tolerate cyclic strain well. ED copper can suit static flex, rigid-flex sections, and cost-sensitive designs, but the specified foil grade and tested stackup matter more than the category name.
A flex circuit can pass electrical test yet crack in service when its copper and bend geometry do not match the motion. Start the RA copper vs. ED copper decision with the actual bend cycle, radius, and installation method.
The sections below turn those inputs into a material choice and a fabrication checklist.
What Is RA Copper
Rolled annealed copper is wrought foil rolled to the target gauge and heat-treated. This process elongates grains mainly in the foil plane, helping the conductor tolerate repeated deformation before fatigue cracks form.
RA copper is also relatively smooth. Its main flex advantage is mechanical: thin copper, smooth traces through the bend zone, and a controlled neutral axis reduce cyclic strain.
What Is ED Copper
Electrodeposited copper is plated onto a rotating drum and peeled off as foil. Conventional ED copper has distinct drum and matte sides and generally resists repeated high-strain bending less effectively than comparable RA copper.
ED copper is not one uniform product. High-elongation, reverse-treated, and very-low-profile grades behave differently, so use laminate data and flex test results for critical designs.
RA Copper vs. ED Copper Comparison
This table summarizes the practical differences that matter during flex PCB selection.
| Decision factor | RA copper | ED copper |
| Manufacturing route | Rolled and annealed | Electrodeposited on a drum |
| Typical grain form | Elongated in the foil plane | More columnar in conventional grades |
| Repeated bending | Preferred starting point | Use only with qualified foil and testing |
| Static installation bend | Suitable | Often suitable and economical |
| Surface profile | Generally smoother | Varies by treatment and foil grade |
| Design priority | Fatigue life and ductility | Cost, adhesion, and stable routing |
| Procurement check | Grade, temper, thickness, grain direction | Grade, elongation, profile, treatment |
When Flexible PCBs Should Use RA Copper
RA copper should be the default candidate when a flex PCB moves during normal operation. Confirm it against strain, copper thickness, trace geometry, and the complete stackup.
Hinges and sliding mechanisms: Use RA copper for foldable displays, laptop hinges, and camera modules where the circuit bends through many cycles.
Robotics and moving sensors: Prioritize thin copper, large bend radii, and conductors routed perpendicular to the bend line; avoid vias, pads, and sharp trace corners in the active bend zone.
Medical and wearable devices: Select RA copper when normal use repeatedly wraps or flexes the circuit. Qualify the actual stackup under the intended temperature, radius, and cycle count.
High reliability static folds: RA copper can add margin where a one-time fold is tight or assembly handling is hard to control, although layout corrections should come first.
For reference, 1 oz copper is about 35 micrometers and 0.5 oz about 18 micrometers. Thinner copper usually lowers strain, subject to current and yield requirements.
When Flexible PCBs Should Use ED Copper
ED copper is reasonable when a flex section bends mainly during installation and then remains fixed. It can also suit rigid-flex areas without continuous motion.
Static cable replacement: Use ED copper for a formed interconnect that is installed once with a generous radius and supported against vibration.
Cost-sensitive electronics: ED copper may reduce material cost, but confirm that the selected grade meets the required elongation and adhesion targets.
Fine routing with limited motion: A qualified low-profile ED foil can support dense circuitry, provided the supplier confirms the foil treatment, thickness, and compatible laminate system.
Prototype validation: Do not approve a dynamic design from continuity testing alone. Build representative coupons and run bending tests to the product's radius and movement pattern.
For any RA copper vs. ED copper decision, request the foil designation in the stackup and prevent an unapproved substitution during production.
Is RA copper always better than ED copper for flex PCBs?
No. RA copper is usually favored for repeated flexing, while ED copper can be suitable for static bends and cost-sensitive constructions. The correct choice depends on foil grade, thickness, bend strain, and validated cycle life.
Can ED copper be used in a dynamic flex circuit?
Yes, but only when the specific ED foil and finished construction are qualified for the required motion. High-elongation or specialized ED grades may perform well at low strain, so test data should replace assumptions.
What information should be sent to the PCB manufacturer?
Provide the dynamic or static classification, minimum bend radius, bend angle, target cycles, copper thickness, grain-direction requirement if applicable, and a drawing of the bend zone. Mark no-via and no-component areas clearly.
How can copper cracking be reduced in a flex PCB?
Use a larger bend radius, reduce total thickness, route traces smoothly across the bend, stagger conductors on opposing layers, and keep holes and solder joints outside the bend zone. Then test production-representative samples under the real motion profile.
