Quick Turn PCB Prototyping: What Affects Lead Times
QUICK ANSWER For quick turn PCB prototyping, a 24-hour rush quote covers fabrication of an eligible bare board. Your order can spend extra time in engineering review before the build or with the carrier after it. If you're booking lab time, ask when the board can go into production, when it can ship, and when it's expected to arrive.
PCBgogo offers a 24-hour rush option for eligible orders. After engineering review, confirm when the build clock starts and whether any approvals or payment are still pending. If you need populated boards, confirm a separate PCB assembly schedule that accounts for component availability.
Where a Rush PCB Order Can Slip
Start with the latest completed step on your order. A board held for an engineering answer needs a different response from one that has cleared inspection and is waiting for pickup.
| Stage | What can add time | What to do |
| File review | The drill file is missing, or the drawing and the order disagree on how a slot is plated. | Send one complete file set and confirm which slots are plated or unplated. |
| Production | A special laminate needs sourcing, or inspection finds a defect that requires a remake. | Ask which requirement or production step is holding the job and get a revised ship date. |
| Shipping | The boards are packed, but the carrier hasn't picked them up or the parcel is held at customs. | Check the first carrier scan and confirm any paperwork the carrier needs. |
How to Prepare for Quick Turn PCB Prototyping
Decide what the board has to prove before you choose the build options. A two-layer FR-4 board for power bring-up may work with the standard green solder mask. If you're validating a controlled-impedance interface, confirm the stackup before ordering so the prototype represents the design you intend to test.
Check the exported files. Open the actual ZIP you'll upload in a Gerber viewer. Verify the copper layers, closed board outline, and NC drill data. Make sure the holes and slots line up with the pads and outline.
Match the quote to the drawing. Check layer count, thickness, copper weight, and surface finish. For controlled impedance, include the target, tolerance, and affected layers or nets. Flag any material or finish that needs approval before substitution.
Give engineering a reachable contact. Assign someone who can answer design-for-manufacturing (DFM) questions across time zones. If you revise a file, send a complete ZIP with a new revision name and confirm which version is released for production.
What to Ask When Your PCB Order Is Late
Send the order number and board revision. Ask what is holding the job, whether the factory needs a decision from you, and when the boards can ship. Get the revised date in the factory's time zone. If the boards have shipped, use the carrier scan and delivery estimate to reschedule your lab work.
For your next quick turn PCB prototyping order, share your latest acceptable arrival date when you request a PCBgogo fabrication quote. Include the destination ZIP or postal code so you can check the build and transit estimates together.
Get a Free Quote >
