Importing PCB from China: Common Customs Inspection Reasons & Prevention Tips
Importing PCB from China is usually straightforward&mdash, until a shipment is held for customs inspection. For hardware teams, even a short delay can affect prototype validation, production schedules, and launch dates. Storage fees, document requests, and repeated handling can also add unnecessary cost and risk to sensitive boards.
The good news is that most PCB customs holds are preventable. They are commonly caused by incorrect classifications, inconsistent paperwork, or a mismatch between declared and physical goods. Below are the key risks and practical ways to reduce customs clearance delays for US, EU, and UK shipments.
QUICK ANSWER 1. Use the correct HS/HTS code: Clearly distinguish a bare PCB from an assembled PCBA based on the actual product. 2. Keep all shipment documents consistent: Match the product name, quantity, value, and specifications across invoices, packing lists, and supplier documents. 3. Declare a reasonable customs value: Do not list samples as “zero value,” even when they are provided free of charge. 4. List included items accurately: Declare accessories, cables, ICs, and assembled components separately when required. 5. Review documents before dispatch: Have your PCB supplier and local customs broker verify shipment paperwork in advance. 6. Prepare compliance documentation: Keep RoHS, material declarations, and product-compliance records ready when required by the destination.
Top Reasons for PCB Customs Inspection
1. Incorrect HS or HTS Code Classification
Wrong tariff classification is one of the most frequent reasons a PCB from China is stopped at customs. Bare rigid PCB, flexible PCB (FPC), aluminum PCB, thick-copper PCB, and assembled PCBA are not always treated the same for declaration purposes.
A common mistake is declaring PCBA as a bare board. Once a board includes mounted chips, connectors, or other electronic components, customs may consider it a different product category. This can lead to reclassification, duty adjustments, document requests, and shipment detention.
The correct code depends on the product's actual condition, destination country, and intended use. Confirm the HS or HTS code with a qualified customs broker rather than relying only on a previous shipment.
2. Undervaluation or Inconsistent Declared Value
Customs officers often compare the commercial invoice, purchase order, packing list, courier declaration, and the goods themselves. If the declared value appears unusually low—or does not match the documents—your shipment may be selected for review.
"Free sample" does not mean zero customs value. Even prototype boards have material, fabrication, and shipping value. Declaring a realistic nominal value with wording such as "prototype PCB sample, not for resale" is typically more credible than declaring zero value.
3. Incomplete or Non-Compliant Documents
A vague product description such as "electronics" or "PCB parts" can create avoidable questions. Customs paperwork should clearly identify the shipment, for example:
Bare printed circuit boards, unassembled
Flexible printed circuit boards, unassembled
Aluminum-core printed circuit boards
Printed circuit board assemblies, populated with components
For certain destinations or customer requirements, you may also need RoHS declarations, material data sheets, certificates of origin, or other compliance documents. Missing paperwork does not always cause an inspection, but it can make a routine review much slower.
4. Physical Goods Do Not Match the Declaration
A declaration mismatch is a major customs risk when shipping PCB from China. For example, a parcel may be declared as bare PCB but contain populated boards, loose ICs, cables, batteries, adapters, or programming fixtures.
Quantity, weight, dimensions, and product descriptions should also align with the packing list. If bare boards and PCBA are shipped together, identify them separately on the invoice and packing list instead of using one general description.
5. Packaging and Label Problems
Poorly marked cartons can delay identification during customs review. Use clear outer-carton shipping marks that match the documents, including the consignee, carton number, and product description where appropriate.
For sensitive electronics, use suitable ESD protection, moisture barriers, and stable internal packing. Although protective packaging does not eliminate customs inspection, it reduces the chance of damage if customs opens the shipment.
6. High-Risk Shipment Profiles
High-value PCBA, products containing multiple ICs, unusually large quantities, and repeated shipments to the same consignee may receive additional scrutiny. Some ports and courier hubs also conduct more frequent random inspections.
This does not mean you should split shipments artificially. Instead, make sure the commercial rationale is clear and the documents accurately reflect the shipment.
Practical Ways to Prevent Customs Clearance Delays
Before dispatch, use this checklist:
Confirm the product classification. Clearly separate bare PCB and PCBA, and verify the applicable HS/HTS code with your broker.
Keep every document consistent. Product name, quantity, unit price, total value, weight, and country of origin should match across invoices and packing lists.
Use accurate product descriptions. Avoid generic terms such as "electronic goods" when a more precise description is available.
Separate mixed products. If one parcel contains bare boards, PCBA, and accessories, list each category separately.
Prepare supporting documents early. Keep RoHS declarations, material information, and order records available before the shipment reaches customs.
Pre-screen with your supplier. A PCB manufacturer experienced in international exports can identify mismatched wording or missing details before handover to the courier.
PCBgogo's export team pre-audits documentation before PCB shipments. We review HS coding, commercial invoices, and packing lists to reduce unnecessary customs hold risks. Whether you order bare PCB, FPC, aluminum PCB, or PCBA, our team standardizes declaration descriptions and checks supporting documents such as RoHS declarations when required. This helps customers importing PCBs from China keep hardware projects moving on schedule.
Get a Free Quote >
Is PCBA more likely to trigger customs inspection than bare PCB?
Often, yes. PCBA contains mounted components and may require a more detailed product description and classification than an unassembled bare PCB.
Can I declare PCB samples with zero value?
It is generally safer to declare a reasonable customs value, even for free samples. Zero-value declarations can appear inconsistent because the goods still have manufacturing value.
Will DDP shipping reduce PCB customs inspection risk?
DDP may simplify the importer's logistics process, but it does not eliminate customs inspections. Accurate classification and paperwork are still essential.
How long does a PCB customs inspection take?
Simple reviews may be resolved within a few business days, while inspections requiring revised documents, valuation review, or physical examination can take longer.
Does an RCEP certificate reduce customs audit probability?
No. A certificate of origin may help with preferential tariff treatment where applicable, but it does not guarantee that customs will not inspect the shipment.
Most PCB customs holds are caused by incorrect HS codes, undervaluation, vague descriptions, or inconsistent documents— not purely random inspection. When importing PCBs from China, accurate classification, clear paperwork, and early coordination with your supplier and broker are the most effective ways to avoid delays.
Disclaimer: Customs rules vary by country, port, product classification, and shipment method. This article is general guidance only. For complex shipments, consult a licensed local customs broker.
