HS Code for PCB Imports: How to Avoid Costly Customs Errors
6 0 Oct 12.2026, 17:53:29
KEY TAKEAWAYS  The standard six-digit HS code for a bare printed circuit is 8534.00. This normally covers rigid, flexible, rigid-flex, multilayer, HDI, and metal-core boards when they contain only the printed conductive pattern and permitted connecting elements. A populated PCBA may require a different code based on its function and destination country.
A small classification error can delay a PCB shipment, change the duty calculation, or trigger a request for technical documents. The practical challenge is that "PCB" may describe a bare board, a populated assembly, or even an unfinished laminate, while customs rules treat those products differently.
This guide explains the HS code used for bare printed circuits, shows how common board types fit under it, and gives a repeatable workflow for checking the complete national code before shipment.
What Is an HS Code
An HS code is a product classification number used in customs declarations to identify traded goods. The Harmonized System standardizes the first six digits internationally, but each customs territory may add digits for tariff, statistical, or trade-measure purposes.
For printed circuits, the international heading is 8534 and the six-digit subheading is 8534.00. Chapter 85 defines these circuits by how conductor elements, contacts, or printed passive components are formed on an insulating base. The definition excludes active elements such as semiconductor devices. It also allows certain non-printed connecting elements, so classification depends on the imported product as presented, not simply on its marketing name.
HS Codes by PCB Type
Most unpopulated PCB technologies share the same six-digit HS code because layer count, rigidity, and core material do not change the basic identity of a printed circuit. The following table is a starting point, not a substitute for the importing country's current tariff schedule.
Imported productLikely codeClassification rule
Bare rigid PCB8534.00Use when the imported item is an unpopulated printed circuit.
Bare flexible PCB8534.00Flexibility does not change the six-digit heading.
Bare rigid-flex PCB8534.00Rigid and flexible sections can remain printed circuits.
Bare multilayer or HDI PCB8534.00Layer count, microvias, and HDI construction do not by themselves change the heading.
Bare metal-core or ceramic PCB8534.00Use only when the product meets the printed-circuit definition and has no active elements.
Populated PCBAFunction-specificA board with mounted components has no single universal six-digit code; classify its function and applicable parts rules.
Copper-clad laminateNot 8534.00An unetched laminate without a formed circuit is not yet a printed circuit.
How to Find the Correct HS Code for a PCB
The correct HS code comes from the board's condition at import, its construction, and the rules of the destination customs territory. Use this six-step check before preparing the commercial invoice.
1. Confirm the customs territory: Identify the country of import before choosing the full code. National extensions and trade measures differ.
2. Freeze the condition at import: State whether the product is bare, connector-fitted, partially populated, or fully assembled.
3. Build a technical description: Record the substrate, conductor pattern, layer count, board type, mounted components, connectors, part number, and intended function.
4. Search the official tariff: Start with heading 8534 for a bare printed circuit, then review the national subheadings and legal notes.
5. Check measures and origin separately: The HS code identifies the goods; origin rules, preferential rates, and additional duties require separate checks.
6. Escalate ambiguity: For a high-value or recurring shipment, ask the local customs authority about a binding classification ruling before import.
Common HS Code Mistakes and Practical Tips
The most common HS code error is applying 8534.00 to every product called a PCB. That shortcut fails when the shipment contains mounted active or passive components, or when the item is only copper-clad laminate without a printed circuit pattern.
Do not copy an overseas supplier's eight- or ten-digit number without checking the destination schedule. Only the first six digits are internationally harmonized. Avoid selecting a code from the board's end use alone; a bare control board can remain a printed circuit even when designed for a specific machine, while an assembled board may be classified by its electrical function.
When buying both bare boards and assembly from PCBgogo, keep fabrication and assembly items separate on the invoice and packing list. A description such as "unpopulated four-layer FR-4 printed circuit board" gives customs more useful evidence than "PCB sample." Recheck the applicable HS code and trade measures before repeat shipments because national schedules and additional duties can change.
Is 8534 Always the Correct HS Code for a PCB?
No. 8534.00 generally applies to bare printed circuits. A populated board, unfinished laminate, or board that performs a defined apparatus function may fall elsewhere.
Does the PCB Layer Count Change the HS Code?
Usually not at the international six-digit level. Single-sided, double-sided, multilayer, and HDI bare boards generally remain under 8534.00, although national statistical breakouts may differ.
What HS Code Applies to a PCBA?
There is no universal PCBA HS code. Classification normally follows the assembly's function, the equipment it serves, and the legal notes of the destination tariff.
Can the Same PCB Have Different Full Codes in Different Countries?
Yes. The first six digits are harmonized, while later digits are national. Always confirm the complete code in the importing country's current official tariff.
