High-Voltage PCB Design: From Safety Rules to Production
25 0 Oct 13.2026, 16:13:57
KEY TAKEAWAYS  A high-voltage PCB must safely carry hazardous voltage throughout its service life. Reliable high-voltage PCB design starts with the applicable product standard, then sizes clearance, creepage, insulation, materials, and cooling for the real voltage waveform, altitude, pollution, and environment. Testing must confirm the assumptions before release.
A board can pass a bench test and still fail after dust, moisture, heat, or a surge reduces its insulation margin. This guide provides a practical high-voltage PCB design workflow.
What Is a High Voltage PCB
A high-voltage PCB is a circuit board whose defining job is to carry hazardous voltage without flashover, tracking, dielectric breakdown, or unsafe touch current. There is no universal threshold because risk depends on waveform, energy, environment, insulation class, and the end-product standard. Include connectors, vias, slots, board edges, fasteners, and enclosures in the insulation path.
Creepage and Clearance in High Voltage PCB Design
Clearance is the shortest path through air between conductive parts; creepage is the shortest path along an insulating surface. Clearance depends mainly on impulse voltage, overvoltage category, and altitude. Creepage depends on working voltage, pollution degree, material group, and contamination.
Do not use a generic volts-per-millimeter rule. Derive both distances from the applicable standard. Credit slots, solder mask, or conformal coating only when the governing standard and qualification tests permit it.
High Voltage PCB Design Considerations
A safe high-voltage PCB design begins with an insulation-coordination worksheet before layout.
  • Define the stress: Record RMS or DC voltage, repetitive peaks, surge waveform, frequency, source energy, and fault duration at every isolation boundary.
  • Map the environment: Specify altitude, pollution degree, condensation, contaminants, and ventilation. IEC 60664-1 values cover use up to 2,000 m; correct clearance above that altitude.
  • Control geometry: Keep copper, vias, test points, and component bodies outside the required spacing. Allow for board-edge routing tolerance.
  • Plan verification: Provide test access without shortening a surface path. Inspect the assembly because solder, leads, cables, and hardware can defeat the bare-board layout.
Thermal Design for a High Voltage PCB
Thermal design keeps a high-voltage PCB below the limits of its laminate, components, solder joints, and insulation. Estimate switch, magnetic, resistor, and copper losses, then measure temperature rise at maximum load, minimum airflow, and worst ambient temperature.
Use wider or heavier copper, thermal vias, and deliberate airflow where analysis requires them. Keep heat sinks and metal structures from shortening clearance. Confirm the result with temperature cycling and a loaded thermal test.
Material Selection for a High Voltage PCB
Material selection for a high-voltage PCB must address tracking resistance, dielectric strength, thermal endurance, moisture absorption, and manufacturing stability rather than Tg alone.
Material choicePrimary benefitMain cautionPractical use
High CTI laminateResists trackingDoes not replace spacingWhere creepage governs
High Tg FR-4Adds thermal marginTg is not a voltage ratingHot power stages
Ceramic substrateMoves heat efficientlyCost and brittlenessCompact power modules
Safety Standards for a High Voltage PCB
Safety compliance uses a stack of standards, with the end-product standard controlling the final high voltage PCB requirements.
  • IEC 60664-1: Covers insulation coordination up to 1,000 VAC or 1,500 VDC, including clearance, creepage, pollution degree, and altitude.
  • UL 840: Provides an insulation-coordination approach for clearance and creepage when the relevant end-product standard permits its use.
  • IPC-2221: Provides general PCB guidance but does not replace product-safety evaluation.
  • Product standards: Use IEC 62368-1, IEC 61010-1, or IEC 60601-1 where their scopes cover the product. Confirm the required edition and regional deviations.
High Voltage PCB Applications
A high voltage PCB appears wherever power conversion or controlled high electric fields must fit into a compact assembly.
  • EV chargers: Power stages, isolated gate drive, and DC-link monitoring need controlled spacing and thermal paths.
  • Solar inverters: Repetitive switching, pollution, and surges make insulation coordination critical.
  • Industrial motor drives: Fast edges can concentrate fields and couple noise across isolation barriers.
  • Medical power supplies: Leakage current and isolation must follow the medical product standard.
Choosing PCBgogo for High Voltage PCB Manufacturing
A high voltage PCB manufacturer must convert the specified stackup, spacing, materials, and test plan into a repeatable process. PCBgogo offers relevant engineering, material, and inspection options.
  • Engineering review: DFM and stackup review can identify conflicts before fabrication. Mark voltage boundaries and no-substitution materials in the package.
  • Material options: Choices include high-CTI and high-Tg FR-4, thermally enhanced constructions, and ceramic substrates, subject to review and availability.
  • Inspection and testing: Available methods include AOI, electrical and impedance testing, X-ray inspection, and microsection analysis.
  • Production handoff: Release fabrication data, drill files, stackup, copper weights, controlled dimensions, standards, and acceptance tests together.
Successful high-voltage PCB design requires insulation coordination. Define the stress and environment, apply the governing standard, select materials and cooling together, then verify the finished assembly with inspection, hi-pot, and thermal tests.
What voltage makes a PCB high voltage?
No single voltage defines every high-voltage PCB. Classification depends on shock hazard, energy, waveform, environment, insulation, and the product standard.
Can solder mask reduce creepage distance?
Usually, solder mask cannot justify reduced creepage. Credit it only when the applicable standard and qualification tests permit it.
Does a slot increase creepage distance?
A properly dimensioned slot can increase creepage. Its geometry, cleanliness, plating, routing tolerance, and treatment under the governing standard determine whether it counts.
What files should I send for high voltage PCB fabrication?
Send fabrication data, drill files, stackup, materials, copper weights, controlled spacing, outline tolerances, standards, and the electrical test plan. Mark hazardous-voltage boundaries and prohibited substitutions.
