Heat Sink for PCB: Types, Attachment Methods & Selection Guide
525 0 Jun 22.2026, 17:47:23
When a PCB runs hot, components fail early. A heat sink is one of the simplest, most cost-effective fixes — a thermally conductive metal structure that absorbs heat from a component and dissipates it into the surrounding air. Choosing the right heat sink for your PCB, and attaching it correctly, can mean the difference between a reliable product and an expensive warranty problem.
What Is a PCB Heat Sink?
A PCB heat sink is a passive cooler — typically aluminum or copper — attached to high-power components such as processors, MOSFETs, and voltage regulators. It works through conduction: heat flows from the hot component into the heat sink's low-resistance metal body, then spreads across the fin surface and transfers to the air by convection.
The key performance metric is thermal resistance (°C/W). The lower the value, the more heat the sink removes per degree of temperature rise. A quality thermal interface material (TIM) — paste, phase-change pad, or graphite sheet — between the component and the heat sink is essential to eliminate air gaps that would otherwise act as insulators.
PCB Heat Sink
Common Types of Heat Sinks for PCB
  1. Stamped: Punched from thin aluminum sheet. Lightweight, inexpensive, suitable for low-power components (< 5 W) such as small regulators and microcontrollers.
  2. Extruded: Aluminum forced through a die to create finned profiles. Excellent performance-to-cost ratio; the standard choice for power supplies, motor drivers, and RF amplifiers (10–100 W).
  3. Bonded Fin: Thin fins bonded to a base plate for maximum fin density. Used in base stations, inverters, and industrial controls where high heat loads meet restricted space.
  4. Pin Fin: Array of cylindrical pins; performs equally in all airflow directions. Ideal for turbulent airflow environments — servers, graphics cards, telecom hardware.
  5. Clip-On (Board-Level): Attaches to component packages directly via spring clips. No PCB modification required; easy to install and remove. Common in consumer electronics and LED driver boards.
Heat Sink Attachment Methods
How you attach a heat sink matters as much as which type you choose. Each attachment method offers a different balance of thermal performance, permanence, and assembly complexity.
Thermal Tape
Peel-and-stick pressure-sensitive tape with thermally conductive filler. Thermal conductivity: 0.8–1.5 W/m·K. Best for lightweight heat sinks on SMD components under 5 W. Fast to assemble and non-destructive to remove, but not suited for high-power or high-vibration applications.
Thermal Adhesive (Epoxy / Silicone)
A permanently bonding compound that outperforms tape thermally (1.5–3.0 W/m·K) and provides strong mechanical retention. Ideal for 10–30 W applications where rework is not expected. The main drawback: removing the heat sink risks damaging the PCB or component.
Z-Clips
Metal spring clips that anchor to the PCB and hold the heat sink in firm contact without adhesive. Used with a TIM for effective conductivity of 3.0–5.0 W/m·K. Fully reversible — ideal for applications of 20–50 W that may need servicing. Requires mounting anchor points to be designed into the PCB layout.
Push Pins
Spring-loaded pins pass through pre-drilled PCB holes and clip below the board, providing consistent clamping force. Effective conductivity of 3.0–5.0 W/m·K via TIM. Fast to install and remove — the standard choice for high-power CPUs, power transistors, and server components (50–100 W). Requires 2.5–4.0 mm holes planned into the layout.
Attachment Method Quick Reference
MethodConductivity (W/m·K)Power RangeReversible?PCB Modification?
Thermal Tape0.8–1.5< 5 WPartialNone
Thermal Adhesive1.5–3.010–30 WNoNone
Z-Clips3.0–5.0*20–50 WYesAnchor points
Push Pins3.0–5.0*50–100 WYesDrilled holes
* Via thermal interface material (TIM).
How to Choose the Right Heat Sink for Your PCB
  • Calculate thermal requirements first: Determine the component's thermal design power (TDP) and maximum allowable junction temperature. Required thermal resistance = ΔT ÷ P.
  • Match power range to attachment method: Use the table above as a starting point. High-power components (50 W+) need mechanical attachment with TIM — tape will not suffice.
  • Consider serviceability: If the board will ever be reworked or components replaced, avoid permanent adhesive. Z-clips and push pins are the better choice.
  • Plan the PCB layout early: Mechanical attachments (Z-clips, push pins) require holes or anchor features. Design these in before routing — retrofitting is costly.
  • Always use a TIM: Even with a mechanically attached heat sink, a quality TIM is non-negotiable. Dry metal-to-metal contact leaves air gaps that dramatically increase thermal resistance.
A heat sink for PCB is a straightforward solution to a common problem, but only when the type, material, and attachment method are correctly matched to the application. Stamped and clip-on designs handle lightweight, low-power jobs efficiently. Extruded and bonded fin sinks scale to demanding industrial and telecom loads. Thermal tape works for quick, low-power assembly; push pins and Z-clips provide the performance and reversibility that high-power designs require.
Start with your thermal requirements, plan mounting features into the PCB layout early, always pair any attachment with a quality TIM, and validate with testing before production. Get these steps right, and your components will run cooler, last longer, and perform reliably throughout the product's service life.
