Why Does SMT Tombstoning Occur and How to Prevent It?
921 0 Dec 10.2025, 10:33:10
SMT tombstoning is one of the most common PCBA defects in surface-mount assembly, especially for lightweight chip components such as 0402 and 0603 resistors or capacitors. When an imbalance of solder wetting force occurs during reflow soldering, one end of the component lifts and stands upright like a “tombstone,” causing an open circuit failure. This article analyzes the main causes behind tombstoning and provides targeted process solutions to eliminate this defect.
What Is SMT Tombstoning?
SMT tombstoning refers to a condition during reflow soldering in which a chip component stands vertically on one pad instead of being soldered flat across both pads. This defect is typically triggered by uneven solder melt timing, poor pad design, or asymmetric heat transfer. Tombstoning not only reduces assembling yields but also leads to functional failure in PCB assemblies.
Why SMT Tombstoning Occurs and How to Prevent It?
1. PCB Design Issues
Improper PCB layout and pad design are major contributors to SMT tombstoning.
Common PCB-related causes:
  • Inconsistent pad sizes or shapes
    If the left and right pads differ in area, the solder on the larger pad absorbs heat faster, causing it to reflow first and pull the component upright.
  • Unbalanced thermal distribution on the PCB
    Components placed near copper pours, vias, ground planes, or large thermal masses may experience uneven heating during reflow.
  • Inefficient component layout
    When components of different sizes are densely arranged, airflow and heat transfer become inconsistent.
Solutions:
  1. Standardize pad geometry to ensure symmetric size and equal thermal capacity.
  2. Optimize component placement and routing to achieve uniform heat balance across each component.
2. Component-Related Issues
Some component materials or finishes worsen PCBA tombstoning risks.
Causes:
  • Poor component solderability due to oxidation or contamination
    When solderability declines, one side wets more slowly, causing uneven solder pull forces.
  • Very small and lightweight chip components
    The lighter the component, the easier it becomes for surface tension to lift it.
Solutions:
  • Replace components with better solderability or newer surface finishes.
  • Adjust the reflow oven temperature profile to ensure balanced wetting and synchronized solder melt on both ends.
3. SMT Process and Solder Paste Issues
Industry data shows that over 70% of SMT assembly defects, including tombstoning, originate from solder paste printing issues.
Key process-related causes:
  1. Uneven solder paste volume on the two pads
    If one pad receives less paste or the paste height differs, the solder will melt unevenly.
  2. Poor paste release or stencil issues
    Stencil thickness, aperture design, and paste viscosity influence print quality.
  3. Component placement offset
    If the placement machine accuracy is poor, the component may sit closer to one pad, increasing the likelihood of tombstoning during reflow.
Solutions:
  1. Strengthen solder paste printing control.
    • Maintain stencil cleanliness
    • Use high-stability solder paste
    • Deploy SPI (Solder Paste Inspection) after printing
  2. Improve component placement precision by calibrating the pick-and-place machine and ensuring consistent nozzle performance.
  3. Optimize reflow soldering curve settings to ensure synchronized wetting on both pads.
Conclusion: Eliminating SMT Tombstoning with Professional PCBA Process Control
SMT tombstoning is primarily caused by pad design asymmetry, solder paste printing defects, uneven heating, or component solderability issues. By optimizing PCB design, controlling solder paste deposition, refining reflow profiles, and ensuring precise component placement, manufacturers can significantly reduce tombstoning defects and improve PCBA yield.
At PCBGOGO, we provide high-precision SMT assembly and full-process PCBA manufacturing, supported by professional engineering review, advanced placement equipment, SPI/AOI inspection, and strict process control to eliminate defects such as tombstoning, bridging, solder balls, and open circuits. If you need reliable, high-quality PCBA production, PCBGOGO is ready to support your project from prototype to mass manufacturing.
