Why Do White Spots Always Appear on PCB Surfaces? Analyzing the Problem of Solder Mask Blisters in Production
What Are "White Spots" and Solder Mask Blisters?
Causes of Solder Mask Blisters
1. Moisture Entrapment
2. Incompatibility Between Solder Paste and Solder Mask Ink
3. Improper Curing of the Solder Mask
4. Contaminants on the PCB Surface
Impact on PCB Performance
Prevention and Solutions
1. Strict Moisture Control
2. Compatibility Testing
3. Precise Curing Process
4. Surface Cleaning
At PCBgogo, we know the "white spot" problem caused by solder mask blisters like the back of our hand. In our production process, we have very strict quality control. Our expert team regularly checks incoming substrates for moisture to ensure they are all dry. All the materials we use, such as solder paste and solder mask ink, undergo comprehensive compatibility testing. Our curing ovens are the most advanced, with extremely accurate temperature control to ensure the solder mask is properly cured. In addition, we have spent a lot of money on advanced surface cleaning equipment to make sure every PCB surface is clean before applying the solder mask. Through these methods, we strive to reduce the occurrence of white spots and solder mask blisters, providing customers with high - quality PCBs that meet the high requirements of the current electronics industry.
