What Is Rogers PCB?
204 0 Oct 17.2026, 09:48:00
KEY TAKEAWAYS1. Rogers is the material maker: A qualified PCB manufacturer converts its laminates into a finished Rogers circuit board.2. Choose a grade, not a label: RO4003C, RO4350B, RO3003, RT/duroid 5880, and TMM products differ in Dk, loss, thermal behavior, and processing.3. Use the correct Dk: Process Dk supports material control; design Dk is usually the better modeling input. Confirm the value, method, thickness, and copper profile.4. Fabrication still controls performance: Stack-up, copper roughness, geometry, plating, registration, and finish all affect a Rogers PCB.5. Send a complete package: State the grade, dielectric thickness, copper, stack-up, impedance, frequency range, finish, tolerances, and coupon needs.
What Is a Rogers PCB?
A Rogers PCB is a circuit board that uses one or more laminate products made by Rogers Corporation. Rogers manufactures circuit-board materials, including copper-clad laminates and bonding products; it does not define one universal substrate called "Rogers." The finished board is fabricated by a PCB manufacturer using a specified Rogers material family and construction.
That distinction matters during sourcing. Writing only "Rogers circuit board" leaves the grade, dielectric thickness, copper foil, bond material, stack-up, and impedance model unresolved. Two Rogers PCB builds can therefore have very different loss, cost, and fabrication routes.
The material is chosen because its dielectric constant (Dk) and dissipation factor (Df) are characterized for RF work. It cannot rescue a weak layout: trace geometry, plane continuity, transitions, launches, copper roughness, and fabricated dielectric thickness still determine loss and impedance.
Rogers PCB Characteristics
A Rogers PCB is valued for predictable electrical behavior, but each characteristic must be tied to a specific grade and test condition. The table below shows what engineers should verify instead of assuming every Rogers PCB board behaves the same way.
For a Rogers PCB project, put these properties into the stack-up review rather than leaving them as purchasing notes.
CharacteristicWhy it mattersWhat to verify
Controlled DkSupports repeatable impedance, phase, antenna dimensions, and filter response.Use design Dk when supplied; record frequency, method, thickness, and copper profile.
Low DfReduces dielectric loss in RF paths, feeds, and resonant structures.Compare at the target frequency; conductor and finish losses still contribute.
Thermal stabilityLimits electrical drift across assembly and service temperatures.Check thermal coefficient of Dk, decomposition temperature, and axis-specific CTE.
Moisture resistanceHelps stabilize impedance and loss in humidity.Confirm the test condition; low absorption does not replace environmental protection.
Manufacturing behaviorDrilling, bonding, registration, and plating vary by resin system.Require process review for PTFE and mixed-material multilayers.
Rogers PCB Material Formulations and Series
Rogers PCB materials fall into several formulation families, and the resin and reinforcement system often matters as much as the product number. The following groups cover the grades most engineers encounter when specifying a Rogers circuit board.
These Rogers PCB families should be compared by circuit need and fabrication route, not by Dk alone.
FamilyFormulation and reference valuesBest-fit use
RO4000 seriesHydrocarbon-ceramic thermoset. RO4003C has process Dk 3.38 ± 0.05 and Df 0.0027 at 10 GHz; RO4350B has process Dk 3.48 ± 0.05 and Df 0.0037.Cost-conscious RF multilayers, antennas, power amplifiers, and hybrid RF/digital builds using familiar PCB processes.
RO3000 seriesCeramic-filled PTFE. RO3003 has Dk 3.00 ± 0.04 and Df 0.0010 at 10 GHz, with stable Dk across temperature and frequency.Automotive radar, millimeter-wave circuits, filters, and phase-sensitive RF designs.
RT/duroid 5000Glass-microfiber-reinforced PTFE. RT/duroid 5880 has Dk 2.20 ± 0.02 and Df 0.0009 at 10 GHz.Very-low-loss microwave, broadband, radar, satellite, and antenna circuits where loss has priority.
TMM seriesCeramic-filled thermoset materials spanning multiple Dk values; TMM 10 has process Dk 9.20 ± 0.23 and Df 0.0022 at 10 GHz.Compact microwave circuits, patch antennas, filters, and designs needing high Dk with copper-matched CTE.
CLTE seriesCeramic-filled, woven-glass-reinforced PTFE. CLTE-XT has design Dk 2.94, Df 0.0012, and Z-axis CTE of 20 ppm/°C.Phase-sensitive, thermally cycled, and high-reliability plated-through-hole designs.
Do not copy a Dk number from a summary directly into a field solver. RO4003C, for example, lists a process Dk of 3.38 but a design Dk of 3.55. Model the Rogers PCB with the value recommended for the exact material, thickness, copper, structure, and frequency range.
Rogers Material vs FR-4
The main difference between Rogers material and FR-4 is not simply "high frequency versus low frequency." A Rogers PCB provides more deliberately characterized RF properties, while FR-4 remains the economical and mechanically familiar choice for many digital, control, and power sections.
Decision pointRogers PCBFR-4 PCB
Electrical lossLow-loss grades serve microwave and millimeter-wave paths.Loss is usually higher and varies by resin, frequency, and glass construction.
Dk controlGrade-specific design data support RF modeling and phase control.Standard grades may have broader variation and less RF-focused data.
FabricationPTFE grades need specialized handling and hole preparation.Mature, broadly available drilling, lamination, desmear, and plating.
CostMaterial, handling, test, and scrap risk raise total cost.Usually lower material and processing cost.
Best useRF front ends, antennas, radar, low-loss feeds, precision filters, and phase-sensitive circuits.Digital logic, control, low-to-moderate-speed interconnects, and cost-driven general electronics.
A hybrid stack-up can reserve Rogers circuit board material for RF layers and use FR-4 elsewhere. The fabricator must account for resin flow, bond material, thickness, drilling, CTE mismatch, and registration. Approve the production stack-up before final impedance tuning.
Why Choose Rogers PCB Material?
Choose Rogers PCB material when the electrical or environmental requirement cannot be met reliably with the intended FR-4 system. The decision should come from a loss budget, impedance and phase tolerance, temperature range, power level, mechanical constraints, and production volume rather than from operating frequency alone.
  • Protect the RF loss budget: Low Df helps long lines, antenna feeds, filters, and high-Q resonators when dielectric loss is significant.
  • Control phase and impedance: Characterized Dk supports consistent line dimensions, electrical length, couplers, filters, and antennas.
  • Manage temperature drift: Low thermal coefficient of Dk can stabilize resonant frequency and phase in outdoor, automotive, aerospace, and industrial equipment.
  • Match material to heat: Thermal conductivity and CTE matter, but the path also includes copper, vias, interfaces, airflow, and the enclosure.
  • Build only where it adds value: For mixed RF and digital systems, a hybrid Rogers PCB board can reserve premium laminate for sensitive layers instead of converting the entire stack-up.
Compare simulation with a representative coupon or prototype. Data-sheet Df is not total board loss; copper profile, finish, geometry, launches, radiation, and fabrication variation remain.
Rogers PCB Applications
Rogers PCB applications are concentrated where signal loss, phase stability, frequency accuracy, or operation across temperature justifies a specialized laminate. The material grade should be selected from the actual circuit function, not from the market label alone.
  • 5G and wireless infrastructure: Power amplifiers, filters, combiners, phased arrays, and feed networks need controlled impedance and repeatable phase.
  • Automotive radar: Short-range and long-range radar near 77 GHz place tight demands on Dk uniformity, copper profile, antenna geometry, and registration; RO3003 is one commonly evaluated material.
  • Aerospace and defense RF: Radar, navigation, electronic-warfare, satellite, and secure communication hardware may use RT/duroid, CLTE, or TMM materials according to loss, temperature, reliability, and mechanical needs.
  • Microwave instrumentation: Generators, analyzers, couplers, attenuators, and calibration structures benefit from stable electrical length and low loss.
  • High-speed digital links: A Rogers circuit board or hybrid build can support long, loss-sensitive channels, but channel modeling should compare it with other qualified low-loss materials rather than assuming one family is mandatory.
  • Industrial RF and sensing: Readers, telemetry units, imaging electronics, and precision sensors may use a Rogers PCB when temperature, moisture, or frequency stability affects calibration and field performance.
How to Specify a Rogers PCB for Manufacturing
A manufacturable Rogers PCB specification tells the fabricator exactly what must be controlled and which decisions remain open. Use this five-step handoff to prevent substitutions, quotation delays, and impedance surprises.
  1. Name the laminate: State grade, dielectric thickness, copper foil and weight, and substitution policy. "Rogers or equivalent" is not precise enough.
  2. Freeze the stack-up: Identify RF layers, planes, bond materials, finished thickness, copper, and pure or hybrid construction before final trace tuning.
  3. Define controlled structures: List impedances, tolerances, reference layers, coupons, and critical phase or length matching. Add the frequency band when useful.
  4. State fabrication details: Specify finish, annular ring, via type, filling, capping, back drilling, edge plating, and special inspection. Require PTFE process review.
  5. Plan verification: Agree on impedance reports, microsections, material certificates, first-article inspection, and RF coupon testing. Prototype representative geometry.
A Quality-Focused Rogers PCB Manufacturer: PCBgogo
A Rogers PCB manufacturer must combine material availability with controlled lamination, drilling, plating, registration, impedance engineering, and inspection. PCBgogo's published capability matrix lists pure RF and hybrid constructions using Rogers RO4003C, RO4350B, and 5880 materials, covering common hydrocarbon-ceramic and PTFE-based requirements. Confirm the exact 5880 product designation in the purchase specification.
For each Rogers PCB project, confirm the proposed production stack-up and the material availability before releasing impedance-critical artwork.
This Rogers PCB checkpoint prevents avoidable redesign after quotation.
Published PCBgogo capabilities list Rogers PCB builds from 1 to 14 layers, controlled impedance with tolerance down to ±3% on reviewed constructions, and qualified 3/3 mil trace and space on applicable 1 oz high-frequency builds. Available finish options include ENIG, immersion silver, OSP, lead-free HASL, and hard gold; select the finish for RF loss, assembly, wire bonding, contact wear, and shelf-life needs.
Submit Gerber or ODB++ data, drills, netlist, drawing, stack-up, impedance table, material callout, copper, and quantity. PCBgogo can check feasibility before the Rogers circuit board geometry is locked, especially for hybrid lamination, PTFE hole preparation, tight impedance, RF launches, and multilayer transitions.
Rogers PCB FAQ
Is Rogers PCB a brand of finished circuit board?
No. Rogers Corporation manufactures the circuit materials, while a PCB fabricator manufactures the finished Rogers PCB. Always specify the laminate grade and construction instead of treating "Rogers" as one generic material.
Which Rogers PCB material is best?
There is no universal best grade. RO4003C and RO4350B suit many cost-sensitive RF multilayers; RO3003 and RT/duroid 5880 target lower loss or higher-frequency work; TMM and CLTE families address high Dk, thermal, phase, or mechanical requirements. Select from the circuit model and manufacturing constraints.
Can Rogers PCB be combined with FR-4?
Yes. A hybrid Rogers PCB board can use a Rogers laminate in RF layers and FR-4 in supporting digital or power layers. The fabricator must validate bond materials, resin flow, CTE compatibility, thickness, registration, drilling, and the final impedance model.
Is Rogers PCB always needed for high-frequency circuits?
No. Short traces, low loss budgets, moderate frequencies, and cost-sensitive products may work with a characterized FR-4 or another low-loss system. Use channel or RF simulation and prototype data to identify when a Rogers circuit board provides measurable value.
Why do process Dk and design Dk differ?
They are derived for different purposes and can use different test structures or methods. Process Dk supports material quality control, while design Dk is intended to improve circuit prediction over a stated frequency range. Use the value recommended for the exact Rogers PCB material and confirm it with the fabricator's stack-up.
What files should I send for a Rogers PCB quote?
Send fabrication data, drill files, netlist, drawing, stack-up, impedance table, exact material and copper callouts, finish, tolerances, test requirements, and quantity. A complete package lets the manufacturer assess material availability, hybrid-lamination risk, PTFE processing, and controlled-impedance feasibility before pricing.
Final Selection Advice
A successful Rogers PCB starts with an exact material grade and ends with a production stack-up that the fabricator can repeatedly control. Model with the correct Dk, budget total loss rather than dielectric loss alone, verify the fabrication route early, and prototype critical RF structures before volume production. When these steps are followed, a Rogers PCB board becomes a controlled engineering choice rather than an expensive material substitution.
