How to Fix SMT Pick-and-Place Errors and Component Throwing in Modern Assembly Lines?
1187 0 Dec 10.2025, 10:33:04
Surface Mount Technology (SMT) has become the backbone of modern electronics manufacturing, but even highly automated assembly lines can suffer production losses due to SMT pick-and-place errors. These issues typically occur during component pickup or placement and can lead to defects, component waste, and lower throughput. This article analyzes the most common causes of pickup failures and component throwing, and provides actionable solutions for stabilizing your SMT process.
1. Causes of Component Pickup Errors in SMT Pick-and-Place Machines
During high-speed operation, pick-and-place heads retrieve components from tape feeders and place them onto the PCB. When pickup reliability declines, defects such as missed pickup, dropped components, and misaligned pickup occur. The core causes include the following:
1.1 Insufficient Vacuum Pressure
Component pickup requires stable negative pressure, typically above 53.33 kPa, to secure components during movement. Low vacuum pressure reduces suction force and results in frequent pickup failures.
Key factors include:
  • Vacuum pump degradation
  • Dirty or blocked nozzles
  • Contaminated vacuum filters on each placement head
Regular cleaning and timely filter replacement help maintain stable airflow and suction performance.
1.2 Nozzle Wear or Damage
Worn, deformed, cracked, or clogged nozzles lead to:
  • Reduced negative pressure
  • Unstable component pickup
  • Increased risk of dropped components
Routine inspection and replacement of damaged nozzles are essential preventive measures.
1.3 Feeder Malfunction or Misalignment
Feeder issues directly influence component pickup accuracy:
  • Damaged feeder gears
  • Tape not seated correctly on sprockets
  • Debris under the feeder
  • Worn springs cause improper tape advancement
These conditions may cause component skew, tombstoning, or incomplete pickup. Regular feeder calibration and cleaning help prevent recurring errors.
1.4 Incorrect Pickup Height Setting
The ideal pickup height is when the nozzle just contacts the component surface and then depresses an additional 0.05 mm.
Pickup issues occur when:
  • The nozzle presses too deeply, pushing components into the pocket
  • The nozzle stops too high, failing to establish suction
Fine-tuning the pickup Z-height for problematic components significantly improves pickup consistency.
1.5 Component Packaging Issues
Defective or inconsistent component packaging from suppliers can also cause pickup failures:
  • Incorrect pocket or sprocket pitch
  • Excessive adhesion between the paper tape and the cover tape
  • Undersized tape pockets
  • Variance in component orientation
Improving incoming material inspection reduces the impact of packaging defects on the assembly process.
2. Causes of Component Throwing (Tossing) After Pickup
“Component throwing” occurs when a picked-up component is released before it reaches the solder pad location. The primary causes include the following:
2.1 Incorrect Component Thickness Setting
If the database defines a component thicker than its actual dimension, the nozzle may release the part prematurely—before contacting the solder pad. As the XY table continues its high-speed motion, inertia flings the component away, resulting in throwing.
2.2 Incorrect PCB Thickness Setting
When PCB thickness is overstated, support pins cannot fully lift the PCB to the programmed height. This causes components to be placed in mid-air rather than on the pad, leading to missing placements and increased tossing.
2.3 PCB-Related Issues
Two common PCB conditions contribute to placement inaccuracy:
(1) PCB Warpage
Excessive PCB warpage exceeds machine tolerances, resulting in:
  • Inconsistent z-height
  • Misalignment
  • Incomplete component release
(2) Improper Support Pin Placement
During double-sided assembly, support pins may:
  • Press against components on the underside
  • Fail to support certain areas due to uneven distribution
Both conditions cause PCB bending, preventing proper placement height and increasing the risk of throwing.
Conclusion: Strengthen SMT Pick-and-Place Stability with Professional PCBA Support
Addressing SMT pick-and-place errors requires systematic control of vacuum performance, nozzle condition, feeder calibration, height programming, and PCB support strategy. By optimizing these parameters, manufacturers can significantly reduce pickup failures, minimize component waste, and enhance line efficiency.
If you need a reliable manufacturing partner with robust SMT engineering expertise, precision process control, and end-to-end PCBA services, PCBGOGO offers professional SMT assembly, PCB fabrication, and comprehensive quality assurance to support stable, high-yield production.
