Automatic THT PCB Assembly: How It Changes the Cost and Reliability Equation
7 0 Jul 03.2026, 17:13:52
Ask five engineers why they still spec through-hole parts on a 2026 design, and you'll get five slightly different answers — vibration, field repair, connector pull-strength, high current. But the question that actually decides your production budget isn't  THT or SMT. It's manual, wave, selective, or automatic  — and most of the guidance out there skips straight past it.
What Is THT PCB Assembly?
THT (through-hole technology) assembly inserts a component's leads through drilled holes in the board and solders them on the opposite side, so the joint is anchored mechanically inside the board — not just sitting on top of the pad the way an SMT joint does.
Key Characteristics
  • Leads pass fully through the board via plated through-holes (PTH), not surface pads.
  • Solder forms a barrel joint, filling the plated hole and wrapping the lead on both the top and bottom side of the board.
  • Requires drilling, which adds a manufacturing step and cost that SMT boards skip entirely.
  • Larger footprint per component than the SMT equivalent, since the hole, pad, and lead all need clearance.
  • Compatible with mixed-technology boards — most modern designs run THT and SMT on the same board, not one or the other.
Advantages of THT Assembly
  • Higher mechanical strength — the through-barrel joint resists shock and vibration far better than a surface-mount pad, which is why it's still standard in automotive and industrial gear.
  • Higher current and power handling — through-hole leads dissipate heat better, so connectors, transformers, and power components stay THT even on otherwise SMT-dense boards.
  • Easier field rework — a technician can desolder and swap a through-hole part with a standard iron; many SMT parts need hot-air rework stations.
  • More forgiving for prototypes — no stencil, no reflow profile to tune, which is part of why manual THT still dominates early NPI runs (more on that below).
THT vs SMT: What's Actually Different
CategoryTHT (Through-Hole Technology)SMT (Surface-Mount Technology)
MountingLeads through drilled holesPads on the board surface
Joint strengthHigh — mechanically anchoredLower — adhesion is surface-only
Board densityLower — needs hole + lead clearanceHigher — parts sit closer together
Typical useConnectors, power components, high-vibration partsICs, resistors, capacitors, high-density logic
ReworkSimple — desolder with an ironHarder — needs hot air or reflow rework
Cost at volumeHigher per joint (drilling, insertion time)Lower per joint at scale
Most production boards today aren't “THT boards” or “SMT boards” — they're mixed-technology boards where SMT handles the density and THT handles the joints that actually take mechanical or electrical load. That mix is exactly what makes the assembly method — not just the technology — the decision that matters.
How Automatic THT PCB Assembly Actually Works
Automatic THT PCB assembly runs three linked stages — lead forming and insertion, soldering, and inspection — with machines handling what used to be entirely manual work.
Step 1: Lead Forming & Insertion
  • Axial and radial insertion machines pull components from tape or reel.
  • Leads are cut and formed to match the hole spacing on the board.
  • The machine inserts each lead into the pre-drilled plated through-hole (PTH).
Hole and pad sizing isn't arbitrary here: pad diameter is typically sized at 1.5–2 times the drilled hole diameter, and the hole itself needs enough clearance over the lead that the machine can seat the part without cracking the barrel plating. Get that tolerance wrong and automation stops being an advantage — it becomes the source of the defect.
Step 2: Wave or Selective Soldering
  • Wave soldering passes the whole board over molten solder in a single pass — efficient for boards that are entirely or mostly THT.
  • Selective soldering targets specific joints with a nozzle instead of the whole board — necessary once SMT parts are already reflowed onto the board (more on why below).
Step 3: Inspection
Automated optical inspection (AOI) or X-ray checks for the two defects that show up most often on a through-hole line: cold joints and solder bridging.
Why Manual Insertion Still Beats Automation on Certain THT Boards
Manual insertion still wins whenever a board mixes irregular lead spacing, low unit counts, or components too tall or oddly shaped for an insertion head to grip cleanly.
  • Odd-form components — large transformers, panel-mount connectors, relays with non-standard pin patterns — either can't run through an automatic line at all, or need a custom nest fixture that costs more than hand-placing twenty boards.
  • Prototype and NPI runs — machine changeover and programming time is fixed regardless of quantity, so on a 15-board prototype run, that setup cost never gets amortized.
This is exactly why prototyping and manual THT assembly still show up together in nearly every production plan — it's not nostalgia, it's math.
What Actually Causes THT Solder Defects in Production
Most through-hole defects trace back to one of three causes:
  • Lead-to-hole clearance that's off spec. Too tight, and insertion can crack the pad annular ring or bend the lead before it seats — engineers commonly target a hole roughly 0.1–0.2 mm larger than the lead diameter to avoid this. Too loose, and the joint ends up starved of solder, which can look fine visually but fail a pull test.
  • Thermal shadowing on the wave. A tall component sitting upstream of a shorter one can block solder from properly wetting the shorter part's leads — component orientation on the board matters as much as the soldering profile itself.
  • A layout designed without automation in mind. Neither problem above is really a “soldering” problem — both get built into the board at the layout stage, long before assembly starts.
Manual, Wave, Selective, or Full Automatic: Matching the Method to Your Order Volume
The right THT assembly method comes down almost entirely to unit volume and board mix, not personal preference.
VolumeRecommended MethodWhy
Prototype / NPI (1–50 units)Manual insertion, hand solderingFast to adjust, no tooling cost
Low-to-mid (50–500 units)Automatic insertion + selective solderingHandles mixed THT/SMT boards without re-stressing SMT joints
High volume (500+ units)Automatic insertion + wave solderingConsistent yield with AOI/X-ray inspection at scale
Selective soldering earns its place in that middle tier for a specific reason: if a board already has SMT components reflowed onto it, running the whole thing through a wave a second time risks re-melting or thermally stressing those joints. Selective soldering lets the through-hole side get soldered without touching the rest of the board.
Where Automatic THT Assembly Actually Pays Off
Automatic THT assembly earns back its setup cost fastest on boards built for vibration, high current, or field replacement:
  • Automotive control modules — thermal cycling and constant vibration make SMT-only joints a real reliability risk, so THT connectors and power components stay standard even on otherwise SMT-dense boards.
  • Industrial power supplies and motor controllers — need the heat dissipation a through-hole lead provides.
  • Connector-heavy backplanes — field technicians need a part they can actually desolder and swap without specialized rework tools.
Why does this matter for your production plan? None of these applications tolerate the failure modes that come from forcing the wrong assembly method onto the wrong volume. A connector that works fine on ten hand-soldered prototype boards can fail intermittently at 5,000 units if the automatic insertion tolerances weren't validated first.
Is automatic THT assembly more expensive than manual for small orders?
For runs under roughly 50–100 boards, yes — machine setup and programming time outweighs the labor saved, so manual or selectively-soldered small-batch assembly usually costs less per board.
Can one line run automatic THT and SMT on the same board?
Yes. SMT parts are reflowed first, then THT components are inserted and soldered — usually with selective soldering — so the earlier SMT joints aren't re-exposed to a full wave of molten solder.
What's the biggest reliability risk in automatic THT insertion?
Lead-to-hole clearance that's off spec. Too tight and the machine can crack the board or bend the lead on insertion; too loose and the joint ends up starved of solder — one of the more common causes of failures caught later by X-ray inspection rather than at final test.
Getting Automatic THT Assembly Right, From Prototype to Production
None of this is really about picking a soldering method — it's about a board behaving the same way at 50 units and at 50,000, without a redesign in between. That kind of consistency depends on whether the assembly line can move between manual, selective, and wave soldering without you having to re-spec your hole and pad tolerances every time volume changes.
This is where PCBgogo becomes relevant. PCBgogo runs automatic THT insertion alongside manual assembly on the same production floor, with DFM checks against hole, pad, and clearance tolerances before a single lead gets inserted — so a design validated on a small prototype batch holds up when it scales into a full production run. The result is fewer resoldered joints, more predictable yield, and a shorter path from first prototype to volume order.
