An Ultimate Guide to Pre-Reflow AOI and Post-Reflow AOI: Differences and Functions
2455 0 Dec 10.2025, 10:33:18
Automated Optical Inspection (AOI inspection) has become indispensable in modern SMT assembly as component density increases and zero-defect expectations continue to rise. With the rapid growth of RF modules and the widespread use of metal shielding cans, SMT manufacturers are deploying both pre-reflow AOI and post-reflow AOI to ensure stable PCBA quality. Although both systems rely on optical image capture and comparison algorithms, their objectives, detection capabilities, and process roles differ significantly.
This article provides a comprehensive overview of each AOI stage, explains why both are necessary, and highlights how optimized AOI inspection strategies can greatly enhance production yield and reduce repair costs.
Major Differences Between Pre-Reflow AOI and Post-Reflow AOI
Aspect
Pre-Reflow AOI
Post-Reflow AOI
Main Objective
Detect placement defects before soldering
Detect solder joint defects after soldering
Key Focus
Component presence, position, polarity
Solder quality and joint integrity
Process Stage
Before the reflow oven
After the reflow oven
Repair Difficulty
Easy, no heating required
Harder, requires rework and soldering
Shielding Can Coverage
Can inspect areas before shields are installed
Cannot inspect areas blocked by shields
Why Post-Reflow AOI Inspection Is Essential
Post-reflow AOI is traditionally the most widely used AOI stage in SMT manufacturing. Its primary function is to detect solder-related defects after the PCB exits the reflow oven. By immediately feeding defect data back to the process team, it prevents quality issues from flowing into downstream assembly and final product integration.
Core functions of post-reflow AOI
Post-reflow AOI is mainly responsible for identifying issues such as:
  • Missing components
  • Tombstoning
  • Component skew and rotation
  • Wrong component value or reversed polarity
  • Bent leads or lifted leads
  • Solder bridge
  • Insufficient solder, excess solder
  • Cold solder or open solder joints (limited ability to detect false solder)
Post-reflow AOI provides the final confirmation of SMT quality. However, once a solder defect has already occurred, rework often requires manual heating, soldering, or component replacement. This not only increases repair time but may also risk PCB damage or product scrapping—especially for high-density, multilayer boards.
Therefore, preventing defects before the reflow process becomes equally important.
The Role and Purpose of Pre-Reflow AOI Inspection
As shielding cans and large RF components increasingly block critical areas on PCBs, pre-reflow AOI inspection has gained strategic importance. Its main purpose is to identify placement-related defects before soldering occurs.
1. Detecting placement defects before soldering
Pre-reflow AOI allows manufacturers to verify:
  • Component shift or rotation
  • Wrong component pick
  • Reversed polarity
  • Feeder picking issues
Because the solder has not yet reflowed, wrongly-placed or misaligned components can be corrected immediately without heating or reworking, significantly reducing repair costs.
2. Inspecting areas that will be hidden after reflow
RF modules commonly use:
  • Metal shielding cans
  • Large connectors
  • Mechanical structures
These components often block the camera view of post-reflow AOI systems. By placing pre-reflow AOI before the station that inserts shielding cans, all components beneath the shield can be fully inspected, eliminating blind spots that would otherwise go undetected.
3. Enhancing overall process stability
Pre-reflow AOI improves:
  • SPI + placement + reflow correlation analysis
  • Process traceability
  • Predictive quality control
  • SMT line efficiency
By shifting defect detection earlier in the process, AOI inspection becomes a preventive strategy instead of merely a corrective one.
Why Both Pre-Reflow AOI and Post-Reflow AOI Are Necessary
Some manufacturers question whether post-reflow AOI is still required once pre-reflow AOI is installed. The answer is absolutely yes.
Pre-reflow AOI checks placement quality, but many solder-related defects only occur during reflow, such as:
  • Insufficient solder wetting
  • Voiding
  • Tombstoning caused by temperature gradients
  • Solder ball formation
  • Reflow-induced component lift or shift
Eliminating post-reflow AOI would allow these defects to escape detection and flow into assembly or shipment, creating severe quality risks.
An optimal SMT quality strategy always uses both AOI stages working together:
  • Pre-reflow AOI: Prevent potential issues before soldering
  • Post-reflow AOI: Verify solder joint integrity after reflow
This dual-inspection approach ensures the highest PCBA yield and the lowest rework rate.
Conclusion: Strengthening PCBA Quality Through Effective AOI Inspection
AOI inspection—whether pre-reflow or post-reflow—is a critical quality-control pillar in modern SMT assembly. Pre-reflow AOI prevents placement defects and eliminates blind spots under shielding cans, while post-reflow AOI ensures solder joint reliability. Together, they deliver a robust, data-driven inspection ecosystem that maximizes production yield and minimizes repair costs.
If you need reliable, cost-effective PCBA manufacturing and SMT assembly services, PCBGOGO provides complete engineering support, professional AOI inspection, and high-precision manufacturing capabilities to ensure stable and consistent PCB assembly quality for every project.
