ADAS HDI Substrate Low-Temperature Cracking
547 0 Dec 01.2025, 14:16:45
Automotive ADAS (Advanced Driver Assistance Systems) operate in extremely harsh environments—ranging from –40°C to 125°C temperature cycling and 10–2000Hz vibration. The reliability of ADAS HDI (High-Density Interconnect) substrates used in camera modules, radar, and millimeter-wave units has a direct impact on driving safety.
Industry data shows that non-reinforced ADAS HDI boards experience over 25% cracking after 3000 thermal cycles, and one OEM even recalled 12,000 vehicles after low-temperature cracking caused lane-keeping failure.
With 6 years of experience in automotive ADAS HDI manufacturing, PCBGOGO delivers HDI boards fully certified to AEC-Q200, achieving over 5000 thermal cycles without cracking.
This article breaks down the core failure risks, reinforcement strategies, and verification standards to help OEMs and Tier-1 suppliers prevent ADAS reliability failures.
Why ADAS HDI Substrates Crack Under Low Temperatures
ADAS HDI substrates must comply with AEC-Q200 Chapter 4, which focuses on temperature, vibration, and moisture resistance. The three major reliability risks are:
Thermal Cycling Risk (–40°C to 125°C)
Standard HDI materials (Tg≈150°C) often lose mechanical strength after repeated cycling. After 3000 cycles, interlayer peel strength can drop from 1.8 N/mm to 0.8 N/mm, below the AEC-Q200 minimum of 1.0 N/mm.
Required material performance:
  • Tg ≥ 170°C
  • Toughness coefficient ≥ 3.5
  • High peel strength retention after thermal fatigue
Vibration Risk (10g, 10–2000Hz)
Blind vias and trace corners are highly vulnerable to cracking under high-frequency vibration common in ADAS module locations.
Automotive-grade design requirements:
  • Blind via copper thickness ≥ 20 μm
  • Trace corner radius ≥ 0.1 mm
  • Must meet IPC-6012 Automotive Addendum
Moisture & Heat Risk (85°C / 85% RH)
Poor dielectric stability can degrade radar signal integrity.
AEC-Q200 Clause 4.7 limits dielectric constant fluctuation to ±0.2, otherwise radar attenuation can increase by over 15%.
Recommended Automotive-Grade Materials
  • Shengyi S2116 – Tg 165°C, toughness 3.8, peel strength 1.9 N/mm
  • Rogers RO4835 – Tg 280°C, dielectric stability ±0.05 in humid heat
  • Solder alloy: SnAg3.0Cu0.5 – Better low-temperature ductility
    All above are validated by PCBGOGO Automotive Material Certification.
Practical Engineering Solutions to Prevent Low-Temperature Cracking
Below is the complete technical solution following automotive-grade requirements: materials → structure → process control.
Step 1: Material Upgrades (Automotive-Grade Requirements)
HDI Base Material
  • Shengyi S2116 (Tg165°C) for general ADAS modules
  • Rogers RO4835 (Tg280°C) for near-engine compartments
  • Thickness tolerance: ±0.03 mm
  • Verified under AEC-Q200 Clause 4.2
Solder System
  • SnAg3.0Cu0.5 SAC305
  • Pad copper thickness: 2 oz
  • IMC (Intermetallic compound) thickness: 0.8–1.2 μm (measured via metallographic microscope)
Solder Mask
  • High-temperature type (150°C for 1000h without discoloration)
  • Must meet IPC-SM-840E Class 3
Step 2: Structural Reinforcement
Blind Via Design
  • Via diameter: 0.2 mm
  • Copper thickness ≥ 20 μm
  • Filling rate ≥ 99% (no voids)
  • Verified via X-ray per IPC-A-600G Class 3
Trace Design
  • Minimum trace/space: 0.15/0.15 mm
  • Corner radius ≥ 0.1 mm
  • Power lines ≥ 0.3 mm, copper 2 oz
Edge Reinforcement
For boards in high-vibration zones:
  • Add 0.5 mm FR-4 stiffeners bonded with epoxy
  • Boosts bending strength by 40% (PCBGOGO test result)
Step 3: Process Control (Crucial for Automotive Yield)
Lamination
  • 160°C ±5°C
  • 25 kg/cm2
  • 80-minute dwell (avoids resin brittleness)
Plating
  • Current density: 1.6 A/dm2, 30 minutes
  • Ensures via wall copper ≥ 20 μm, thickness variation ≤ ±1 μm
Cleaning
  • Ultra-sonic cleaning
  • Ion contamination ≤ 1.5 μg/in2 per IPC-TM-650 2.3.28
Reliability Validation (AEC-Q200 Compliance)
PCBGOGO performs full automotive validation:
Thermal Cycling Test
  • Conditions: –40°C (30 min) ? 125°C (30 min), 5000 cycles
  • Must meet:
    • Peel strength ≥ 1.0 N/mm
    • Resistance change ≤ 10%
    • No cracking / delamination
  • Tested using PCBGOGO TH-500 chamber
Vibration Test
  • 10–2000Hz sweep, 10g
  • XYZ directions, 2h each
  • Requirements:
    • No blind via fracture
    • No trace detachment
  • Tested using PCBGOGO VIB-400 vibration table
Moisture & Heat Test
  • 85°C / 85% RH for 1000h
  • Must meet:
    • Dielectric constant fluctuation ≤ ±0.2
    • Insulation resistance ≥ 101 MΩ
PCBGOGO’s Automotive ADAS HDI Service System
PCBGOGO provides a full lifecycle automotive-grade HDI assurance:
? Automotive-Grade Material Traceability
Every batch includes AEC-Q200 compliance documentation.
? Reliability Pre-Testing
  • Thermal cycling
  • Vibration
  • High-humidity dielectric stability
? Mass-Production Process Locking
  • Parameter deviation ≤ ±2%
  • Ensures stable yield during automotive scaling
With these standards, PCBGOGO helps OEMs eliminate ADAS HDI cracking risks and meet global automotive reliability requirements.
