4 Cost-Saving Tips for Double-Sided PCB Board: A Must-Read for Bosses and Production Managers
346 0 Dec 18.2025, 10:37:25
Controlling production costs is always a top priority for bosses and production managers, whether you’re making consumer electronics or industrial products. Many assume that a double-sided PCB board is more expensive than a single-sided one and avoid it. In reality, with the right approach, double-sided PCB boards can maintain excellent performance and save money compared to single-sided boards.
As a PCB industry expert with over 10 years of experience, I'm sharing four practical cost-saving tips for double-sided PCB boards that help reduce unnecessary expenses.
1. Optimize Panelization to Increase Material Utilization by 20%
Material costs account for 30–40% of a double-sided PCB board’s total cost. Maximizing material utilization is the first step to saving money.
Double-sided boards allow more flexible panelization since components can be placed on both sides, reducing the need for large process margins. Smart panel designs can increase material utilization from 70% (typical for single-sided boards) to 90%, effectively producing 20% more products per square meter.
PCBGOGO’s industrial IoT platform offers “smart panelization”, which automatically optimizes Gerber files, adjusts panel sizes based on component layouts, and reduces scrap. A small router client increased material utilization from 65% to 88%, cutting material cost per square meter by 26%.
2. Choose the Right Components and Avoid Over-Engineering
Many manufacturers over-engineer by selecting unnecessarily small or expensive components. For instance, using 0201 resistors when 0402 would suffice increases both component cost and assembly complexity.
For double-sided PCB boards, component selection should match actual needs. Use standard 0402 or 0603 sizes for passives, and cost-effective, high-performance models for critical ICs.
Double-sided boards also support mixed component placement—high-precision components in critical areas, standard parts elsewhere—cutting costs by an additional 10%. PCBGOGO’s DFM review service can suggest cost-effective substitutes. One smart plug client reduced component costs from $8 to $5 per board by switching from all 0201 to 0402 components without affecting performance.
3. Leverage Bulk Production and Cost Sharing
Double-sided PCB boards benefit from economies of scale: the larger the production volume, the lower the unit cost. At PCBGOGO, double-sided SMT assembly starts at ¥268 per square meter, with an extra 10% discount for orders above 500 sqm.
Even small orders can save costs by sharing production runs with other clients, avoiding the expense of opening a dedicated production line. For example, a smart lock client ordering 200 sqm per month would pay 320 ¥/sqm. By combining orders to reach 600 sqm, the unit cost dropped to 290 ¥/sqm, saving 6,000 ¥ per month, without affecting delivery, thanks to flexible production lines capable of handling multiple orders in 3 days.
4. Reduce Rework Losses—High Yield Equals Cost Savings
Rework and scrap are hidden production costs. Single-sided SMT yields are usually 95–97%, meaning extra materials and delays due to rework.
Double-sided PCB boards can achieve yields of 99% or higher, making rework negligible. Over time, this significantly reduces costs and material waste.
Conclusion: Efficiency, Reduced Waste, and Bulk Discounts Drive Savings
The key to cost savings with double-sided PCB boards is simple: increase efficiency, reduce losses, and leverage production advantages.
  • Optimize panelization to maximize material use
  • Select components carefully to avoid over-engineering
  • Take advantage of batch production or shared runs for lower unit cost
  • Maintain high yields to minimize rework
For manufacturers facing cost pressures without sacrificing performance, double-sided PCB boards are a smart choice. PCBGOGO can optimize your entire production process—from panelization and component selection to assembly—and provide online cost estimation and free prototyping so you can see cost details before committing to mass production.
