28-Layer PCB Cost Guide: What Drives the Price and How to Control It
268 0 Jul 22.2026, 17:38:37
Why 28-Layer PCBs Cost So Much More Than Standard Boards
A 28-layer PCB is one of the more expensive categories of rigid board a fabricator builds, and the reason is not simply "more copper." Every additional layer pair adds a full cycle of lamination, drilling, plating, and etching, and yield drops as the process gets more complex — so cost climbs faster than layer count does, not in a straight line. Industry pricing data illustrates the curve clearly: moving from a 12-layer to a 16-layer board can roughly double or triple unit cost even before accounting for material or impedance requirements, and a 24- to 28-layer design can push per-unit prototype pricing well past four figures at low volumes. Understanding why the price behaves this way is the first step to controlling it, since most of the avoidable cost on a 28-layer program comes from decisions made during design, not from the fabricator's margin.
Breaking Down the Cost Drivers
Layer count is the headline number, but it is only one of several variables that combine to set the final price on a 28-layer quote. The table below breaks out the factors that matter most, in roughly the order they tend to move price.
Cost Driver
Why It Matters at 28 Layers
Lamination cycles
A 28-layer board requires multiple sequential press cycles rather than one, each adding process time, handling risk, and yield loss
Material mix
Low-loss laminate on high-speed layers costs significantly more than standard FR-4; the ratio of premium to standard material directly moves price
Impedance tolerance
Tighter controlled-impedance specifications require more careful process control and more extensive coupon testing
Copper weight
Heavier copper for power delivery adds material cost and complicates etching precision on fine-pitch signal layers
Board size and panel utilization
A design that uses standard production panels efficiently costs less per unit than one that stands a large area as scrap
Acceptance class
IPC Class 3 tightens inspection and plating tolerances relative to commercial Class 2, adding cost but reducing field failure risk
Via structure
Blind, buried, or via-in-pad features each add process steps beyond standard through-hole vias
Practical Ways to Reduce 28-Layer PCB Costs Without Sacrificing Performance
None of these strategies involve cutting corners on reliability — they involve spending the premium material and tolerance budget only where the design genuinely needs it, rather than uniformly across the whole board.
  • Verify the layer count is truly necessary. A stackup review sometimes finds two or four layers that can be eliminated through better routing without touching signal integrity — this is the single highest-leverage cost lever available before fabrication even begins.
  • Use hybrid materials deliberately. Apply low-loss laminate only to the layers carrying signals that actually need it; standard high-Tg FR-4 handles the rest without measurable performance loss.
  • Right-size impedance tolerance. Specify tight tolerance only on the nets that require it, and give the fabricator freedom on the remainder of the stackup.
  • Optimize panel utilization. A board outline sized to use a standard production panel efficiently costs meaningfully less per unit than one that stands a large fraction of the panel as unused material.
  • Avoid over-specifying acceptance class. IPC Class 3 is worth its added cost for genuinely high-reliability applications, but applying it by default rather than by requirement inflates cost without adding value on boards that do not need it.
  • Engage DFM review early, not after layout is finished. A pre-production stackup review can catch redundant layers or over-specified materials before they are locked into the design.
Lead Time Expectations: Prototype vs. Volume Production
Prototype lead times for 28-layer boards typically run several weeks rather than several days, driven by the same sequential lamination and extended test coverage that drives up cost. Volume production runs can achieve better per-unit economics once a stable process is established, but the qualification step — confirming the fabricator's process holds consistent yield across a full production panel, not just a handful of prototype units — deserves real time in the program schedule. A common and expensive mistake is treating a successful prototype run as proof that volume production will go equally smoothly; the two are related but not identical questions, and it is worth asking a fabricator directly how their yield data compares between prototype and volume quantities at this layer count.
Red Flags When Comparison-Shopping 28-Layer PCB Quotes
At this layer count, an unusually low quote is a signal to investigate, not necessarily a bargain. A few warning signs are worth checking before committing to a fabricator based on price alone: a quote that does not itemize material mix, impedance verification method, or acceptance class in enough detail to compare against a competing quote; a fabricator that cannot describe its lamination cycle count or layer registration process when asked directly; no mention of coupon-based impedance testing, suggesting controlled impedance is being confirmed by calculation rather than measurement; and reluctance to share real production capability data (yield rates, typical lead times at this layer count) beyond a general capability statement. None of these red flags guarantee a failed board, but together they correlate strongly with the kind of quote that looks attractive on paper and turns expensive after the fact.
Getting an Accurate Quote: What Information Your Manufacturer Needs
A firm, trustworthy 28-layer quote depends on giving your fabricator enough information to price the actual design rather than a generic estimate. At minimum, that means complete Gerber or native CAD files, a defined stackup with material call-outs, impedance targets for controlled-impedance nets, copper weight per layer, surface finish requirement, and the acceptance class (Class 2 or Class 3) the board needs to meet. Providing this up front, rather than iterating on a vague quote request, is what turns a rough estimate into a number you can actually budget a program against.
PCBgogo's online quote calculator accepts uploaded Gerber files directly, alongside Altium, PADs, and Eagle native formats, and routes advanced or high-layer-count stackups to an engineer for review rather than returning an automated estimate that changes once a person looks at the design. Its factories fabricate rigid PCBs across the full 1-to-40-layer range using Shengyi and Kingboard FR-4 laminates alongside Rogers, Taconic, and Arlon high-frequency materials, so a 28-layer quote reflects genuinely qualified capability rather than a stretch. Every order goes through a DFM review before fabrication, controlled-impedance builds are verified with TDR testing on production coupons, and — because PCB fabrication, PCBA assembly, and component sourcing all run within the same factories — the quote you receive covers the full path from bare board to assembled hardware rather than one link in a longer supply chain you have to coordinate yourself.
Total Cost of Ownership: Why the Cheapest Quote Isn't Always the Cheapest Board
Comparing 28-layer quotes purely on unit price misses a large part of the real cost equation. A board that ships slightly cheaper but fails a controlled-impedance spec, arrives with inconsistent registration, or shows a yield problem partway through a production run generates costs that dwarf the original price difference — re-spins, schedule slips, and in the worst case a field failure that has to be traced back through an entire batch of deployed hardware. This is particularly true at 28 layers, where the manufacturing process has enough sequential steps that a single weak link (an under-qualified lamination cycle, an impedance spec confirmed by calculation instead of measurement) can undo the value of everything else done correctly.
A more reliable way to compare quotes is to weigh price alongside documented process capability: real yield data at this layer count, coupon-based test methods rather than simulation alone, and quality certifications that match your application. A quote that is 10-15% higher but comes from a fabricator with a demonstrated track record at 28 layers is very often the cheaper option once the full cost of a failed board — redesign time, schedule delay, and reputational risk on a shipped product — is accounted for.
Q: Why does a 28-layer PCB cost so much more than a 16-layer board of the same size?
Cost does not scale linearly with layer count. Each additional layer pair adds a full lamination, drilling, plating, and etching cycle, and yield drops faster as complexity increases, so the cost curve steepens well beyond a simple per-layer multiplier as boards move deeper into the 20s in layer count.
Q: What is the single most effective way to reduce 28-layer PCB cost?
Confirming the layer count is genuinely necessary through a stackup and routing review is usually the highest-leverage step, since eliminating even two or four unnecessary layers reduces cost more than any material or tolerance optimization applied afterward.
Q: Should I always specify IPC Class 3 for a high-layer-count board?
Only if the application genuinely requires it. Class 3 tightens inspection and plating tolerances in ways that add real cost, so it is worth reserving for boards where the reliability requirement justifies it rather than applying it as a default on every high-layer-count order.
Q: How do I get an accurate quote for a 28-layer board instead of a rough estimate?
Provide complete Gerber or native design files, a defined stackup with material call-outs, impedance targets, copper weight, surface finish, and acceptance class up front. A fabricator with genuine high-layer-count experience, like PCBgogo, will route this level of detail to an engineer for review rather than returning a generic automated estimate.
Q: Is it worth using a manufacturer that can also handle assembly and component sourcing for a 28-layer board?
Generally yes, particularly at this complexity level. Coordinating a bare-board fabricator, a separate assembly house, and a separate parts supplier adds handoff risk on a board where manufacturing precision already matters enormously; a one-stop manufacturer removes that coordination burden.
Turning a Cost Estimate Into a Reliable Budget
The teams that budget 28-layer PCB programs most accurately are the ones that treat the fabricator as part of the design process, not a vendor brought in after the layout is finished. A stackup review before routing is locked, a firm quote based on complete design files rather than a rough estimate, and a clear-eyed comparison of quotes against the red flags above are what separate a program that stays on budget from one that discovers its real cost only after the first production run. PCBgogo's engineering team reviews high-layer-count stackups against its qualified 1-to-40-layer process before issuing a quote, which is exactly the kind of check that keeps a 28-layer program's budget grounded in what can actually be built rather than what a spreadsheet estimate assumed.
