How to Order PCB Online: Step-by-Step Guide for Beginners and Engineers
276 0 Jul 09.2026, 19:04:47
The first time you order a PCB online, the process can feel like it's hiding steps from you. You upload a file, get a price, and then... what? Is the board actually being checked against your design, or just printed as-is? What happens if you made a mistake in your Gerber export? How do you even know when it ships?
This guide walks through the full journey — from preparing your files to what happens after the boards land on your desk — so you know what a manufacturer should be doing at each stage, and what to double-check before you commit to a run. It applies whether you're ordering a single prototype for a weekend project or placing a repeat production order as part of your job.
Before You Click “Order”: Getting Your Files Ready
Everything downstream depends on the files you submit, so it's worth getting this part right before you even open a quote page.
A complete PCB fabrication package usually includes:
  • Gerber files: Gerber files (RS-274X) — the actual manufacturing instructions for each copper layer, solder mask, silkscreen, and the board outline.
  • Drill files: Drill files — hole locations and sizes, usually in Excellon format, exported alongside your Gerbers rather than baked into them.
  • For assembly orders: A BOM (bill of materials) and a CPL / pick-and-place file — required if you're ordering assembly (PCBA), not just bare boards. The BOM lists part numbers and quantities; the CPL tells the assembly line where each component sits and which way it's rotated.
The most common first-order mistake isn't a design flaw — it's an export problem. Missing board outline layers, ambiguous mechanical layers when a design has several (GKO, GM1, GM2, and so on), or leaving out the drill file entirely are all things that can stall or misinterpret an otherwise good design. Most manufacturers offer a free online Gerber viewer; running your zip through one before you upload it anywhere is a five-minute habit that catches a surprising number of these issues.
Step 1: Get an Instant Quote
Once your files are ready, the next step is usually entering your board specifications into an online quote calculator: dimensions, layer count, quantity, board thickness, copper weight, surface finish (ENIG, OSP, HASL, immersion silver, and so on), solder mask and silkscreen color, and — for demanding applications — the Tg rating of the material.
Instant quotes are typically accurate for standard specs, but note that pricing can shift slightly after your files are reviewed if you're using less common options: very fine trace widths, small drill sizes, heavy copper, or custom panelization. Rather than anchoring on a specific number here, it's worth simply entering your real specs into the manufacturer's quoting tool directly, since pricing structures and current promotions change often.
Some platforms let you generate a quote without an account; you'll typically need to register once you're ready to upload files, save the order, or track it later.
Step 2: Upload Your Gerber Files (and What Happens During Review)
After quoting, you'll add the order to your cart and upload your zipped Gerber and drill files — or, for assembly orders, your Gerbers plus BOM and CPL. Most manufacturers accept native Eagle, Altium, or PADs files in addition to Gerber, and will convert them internally, usually asking you to confirm the converted file before it goes to production.
This is the step where a genuine engineering review matters most. A CAM engineer checks the file for board-outline consistency, drill-to-copper clearances, minimum trace/space, and any obvious design contradictions — not just whether the zip opens correctly. If something looks off, you'll typically hear back by email or live chat rather than have the board built as submitted. This is also the point where it's worth watching your inbox; a same-day reply to an engineer's question can be the difference between shipping on schedule and losing a production slot.
Step 3: Confirm Specs, Choose Shipping, and Pay
Before paying, compare the confirmed specs against what you actually intended to order — layer count, thickness, and finish are the three that most often get mismatched between what a customer meant and what got entered. Once approved, most factories start fabrication the same or next business day, so this is your last real checkpoint.
Shipping choice is a genuine trade-off worth thinking through rather than defaulting to whatever's cheapest. Express couriers (DHL, FedEx, UPS) generally deliver worldwide in roughly 3–7 business days; economy postal options take longer but cost less, which can make sense for non-urgent prototypes. If you're ordering internationally for a company, it's also worth confirming the declared value on the shipment in advance, since customs duties are typically the buyer's responsibility and vary by country.
Payment methods commonly include credit card, PayPal, and bank transfer, with the last usually reserved for larger production orders handled through a sales representative.
Step 4: Track Your Order Through Production
Once payment clears, your account dashboard should show the order moving through stages — typically something like under review, in production, testing, and shipped. When the board ships, you'll get a tracking number by email, and it should also appear in your account, linked directly to the carrier's tracking page rather than requiring you to copy it elsewhere.
If you're managing several purchase orders at once — common for procurement roles juggling prototype runs and production batches in parallel — this status visibility matters more than it might seem at first. It's the difference between proactively flagging a delay to your own team and finding out only when a build is already blocked waiting on boards.
Step 5: Inspect Your Boards on Arrival
Before boards go anywhere near an assembly line or a customer, take a few minutes to check them against your design: physical dimensions, layer count (for multilayer boards, a quick cross-section or edge check can confirm this), surface finish, and silkscreen legibility. For assembled boards, visually inspect solder joints and component placement, and run a continuity or basic power-on test before full integration.
If you do spot something wrong, photograph it immediately, before further handling — it's the single most useful thing you can do to make an after-sales claim fast to resolve.
After-Sales: What to Do If Something's Wrong
Reputable manufacturers stand behind their own fabrication process. If a defect traces back to their error — a drilling issue, a solder mask problem, a plating defect — most will replace the order or issue a refund within their stated capabilities. What they generally won't cover is a defect that traces back to your own design file, which is exactly why the file-prep and review steps earlier in this guide matter as much as they do.
When something does go wrong, the fastest path to resolution is usually: note your order number, attach clear photos of the issue, and contact support before the boards are built into a larger assembly or shipped further downstream. Manufacturers with 24-hour support and a dedicated account history make this considerably less painful than chasing an email thread across time zones.
Common First-Order Mistakes to Avoid
  • Skipping file review: Skipping the Gerber viewer step and uploading blind.
  • No buffer quantity: Ordering the exact quantity you need with no buffer for testing or the rare DFM rejection.
  • Assuming the stack-up is right: Not double-checking the layer stack-up on multilayer boards before confirming the order.
  • Not using the remarks field: Leaving special requirements — controlled impedance, existing base-material markings, edge plating — unspecified instead of noting them at order time.
  • Ignoring the shipping trade-off: Defaulting to the cheapest shipping option even when the project timeline is tight.
Where PCBgogo Fits Into This Process
How smoothly this whole sequence goes depends heavily on how much of it actually happens under one roof versus being split across subcontracted vendors. PCBgogo runs design-through-finished-product manufacturing in-house — fabrication, assembly, and testing sit on the same production floor rather than being handed off between separate companies at each stage, which matters most when something needs a fast answer mid-order.
Every order goes through an engineer review before production starts, alongside AOI, X-ray, and ICT inspection depending on the build. For automotive, aerospace, and other traceability-sensitive work, PCBgogo's facilities hold IATF 16949 and ISO 9001 certification, with RoHS-compliant materials and UL-listed processes available. If a question comes up during the file-check window — the exact moment a delay tends to happen — 24-hour support means it doesn't have to wait for the next business day.
If you're ready to see how your own board specs translate into a real quote, the PCB Instant Quote tool on pcbgogo.com is the fastest way to find out.
What file do I need to order a PCB online?
A Gerber file set (RS-274X) with drill data is the standard. Most manufacturers, including PCBgogo, also accept Eagle, Altium, and PADs files and convert them before production.
How long does it take to get a PCB quote?
Instant quote calculators return pricing in seconds based on your entered specs. Final confirmation can take a little longer if your file needs a manual engineer review.
Can I track my PCB order after I pay?
Yes. Your account dashboard shows production status, and you'll receive a tracking number by email once the order ships.
What happens if there's an error in my Gerber file?
A proper engineering review should catch it before production and contact you by email or live chat to confirm a fix, rather than building the board exactly as submitted.
Do I need an account just to see pricing?
Not always. Many instant quote tools let you check pricing without registering, but you'll need an account to upload files, pay, and track the order afterward.
What if my boards arrive with a defect?
If the issue traces back to the manufacturer's process rather than your design file, most factories will replace or refund the order. Document it with photos and contact support right away for the fastest resolution.
